Old 02-27-2008, 06:34 PM   #201 (permalink)
swiss
working on it
swiss's Avatar
Trader Rating: 22 (100%)
I finally manned up and put together a good set of water lines. The old setup was running without water. You can get away with that on a journal bearing turbo as long as you warm up/cool down religiously, but I never really liked it.
The new stuff consists of:
  • Nissport water adapter for the upper radiator hose
  • Nissport-ish adapter for the lower radiator hose
  • 2x 1/8"NPT to -4an fittings
  • 2x -4an 1/4" braided stainless hoses
  • 2x -4an to 1/4"NPT fittings (one 90*, one straight)
  • 2x ATP 14mm 1/4"NPT banjo fittings
I had to modify one of them to clear my compressor outlet. I also ruined one of the fitting in the process (that's why one of them suddenly turned gold).
This is how the banjos look on the center section of the turbo:
Here is the Nissport adapter in place:
The cardboard is there to keep the radiator from getting beat up. It doesn't look like it, but the water line has about 1/2" clearance from the radiator without the cardboard there.
The return side snakes under the turbo behind the motor mount and over to the lower radiator hose:
Old 02-27-2008, 06:40 PM   #202 (permalink)
swiss
working on it
swiss's Avatar
Everything came back from powder coating looking amazing:
I've always wanted a GTIR valve cover and I finally snagged one and had it coated:
Old 02-27-2008, 06:54 PM   #203 (permalink)
swiss
working on it
swiss's Avatar
Put it all together and it looks something like this:
Old 02-27-2008, 10:17 PM   #204 (permalink)
Keo
huh??
Keo's Avatar
Trader Rating: 40 (100%)
Clean and looking good as always, I've said this before but I'll say it again. I like this thread!!
edit: mostly black engine bay is HOT!!
Keo is online now   Reply With Quote
Old 02-28-2008, 12:42 AM   #205 (permalink)
projectmk3
"Boost Before Looks"
Trader Rating: 16 (100%)
this thing is purty!!!!!
projectmk3 is offline   Reply With Quote
Old 02-28-2008, 01:00 AM   #206 (permalink)
srlucino
200sx going JDM
wow man, I always loved your clean and awesome work.
those crystal clears looks really good. nice car man.
srlucino is offline   Reply With Quote
Old 02-28-2008, 10:54 AM   #207 (permalink)
unijabnx2000
where do i put it?
you never took pictures of the catch can in place and hooked up
bump
FS: car audio
FS: boost controller
Old 02-28-2008, 11:09 AM   #208 (permalink)
eric96ser I am a moderator
eric96ser's Avatar
Looks good Dave.
1991 Sentra SE-R
The community is here.
Old 02-28-2008, 12:10 PM   #209 (permalink)
veilside180sx
98 SE
Looks much more complete. Beautiful work man.
Koni www.koni-na.com
www.nissanroadracing.com
Old 02-28-2008, 12:19 PM   #210 (permalink)
MR-4Door-SR20DE
Weekend Warrior
Trader Rating: 32 (100%)
Originally Posted by eric96ser View Post
Looks good Dave.
x 2......Nice job you have been doing on the car. I like the way you have been taking your time. Getting things done the RIGHT way.!
+rep! from me.......
BEND BUT DON'T BREAK
93 SE-R "The Daily Re-Up" Is In Progress
Project-4Door-B13 "Building it one paycheck at a time"
FB1 - FB2 - SR20 storage building part-out LINK
MR-4Door-SR20DE is offline   Reply With Quote
Old 02-28-2008, 02:00 PM   #211 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Did you put your IAC hose before or after the turbo? Looks amazing! I hope mine is NEAR that pretty when its done.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 02-28-2008, 05:42 PM   #212 (permalink)
sr20SE
Former Granite SE HOTness
Everything is looking daam good!
B15 SE Granite Hotness
Mods: AEM/Hotshot/Stromung Catback Cosmetics: Brig Magline 8 wheels w/ Kuhmo MX tires, Stillen Lips, spec headlights 35% tint, HIDS Suspension: Tein Basics. Megan FSTB
Brakes: Powerslot rotors, HAWK pads, SS lines
Oooh....sexy. That's gotta be one of the cleanest B15's ever. Top 10 material right there for sure.
sr20SE is offline   Reply With Quote
Old 02-28-2008, 10:04 PM   #213 (permalink)
Nismo_2.0
Man that is the cleanest engine bay I have ever seen..
I have only 1 question. What exactly happened with the RR motor for the oil to go like that...was it turbo related or the cams maybe? or Just normal wear and tear or a bearing maybe?
Reason I ask is that I have a B15 with the RR that I will be boosting very soon and this thread is now my new bible...... I'll be running the T25 setup and when you blew the motor it kinda threw me off a little.
Thanks in advance.
Nismo_2.0 is offline   Reply With Quote
Old 02-29-2008, 12:18 PM   #214 (permalink)
pedronx2k
the ONLY nx in schaumburg
you get my vote for cleanest b14 i have ever seen.........PERIOD!!!!!
pedronx2k is offline   Reply With Quote
Old 02-29-2008, 12:21 PM   #215 (permalink)
2dr_sentra
Slut Butter
Trader Rating: 31 (100%)
hey swiss, have you had any issues with your Hallman..? im having some with mine, its building up about 9psi when its suppose to be at stock boost. I have mine T'd into the coldside of the piping not the hotside like you do.
97 200SX SE-R w/SR20DE+T and S4 cams
2007 Versa SL 6speed
http://www.cardomain.com/ride/2035028
Xbox gamertag - ColonelYoshi
Old 02-29-2008, 03:47 PM   #216 (permalink)
cburwell
B15 Bubble
Are those banjo fittings for the coolant inlet and outlet from APT turbo? What was the one hitting that you had to cut it down?
cburwell is offline   Reply With Quote
Old 03-02-2008, 11:18 AM   #217 (permalink)
summat
Loving this project dude. I'm turbo'n my N/A SR20DE here in the uk. Don't suppose you can tell me the part numbers for the Water Temperature Adapters?
summat is offline   Reply With Quote
Old 03-02-2008, 02:54 PM   #218 (permalink)
SENTRASER
SENTRASER's Avatar
www.nissport.com
Old 03-02-2008, 04:43 PM   #219 (permalink)
swiss
working on it
swiss's Avatar
