Old 12-01-2006, 08:28 PM   #41 (permalink)
swiss
swiss's Avatar
Trader Rating: 20 (100%)
I appreciate the ideas guys. I'm going to get back under there again tomorrow to get a better look at things with bracket trimming in mind.
Old 12-01-2006, 08:30 PM   #42 (permalink)
swiss
swiss's Avatar
double post, sorry
Old 12-01-2006, 09:49 PM   #43 (permalink)
Octave236
like a stray puppy
I just noticed you live by Calum... you should get your ecu from him...
1993 NX2000: Weekend fun car
1990 Accord: New to me Daily Driver
Octave236 is offline   Reply With Quote
Old 12-01-2006, 10:33 PM   #44 (permalink)
swiss
swiss's Avatar
I haven't met him, but I knew he lived in the area. IDK what the status is on B14 ecu's though. I read a while back that he "cracked" the B14 ecu, but I don't think he's got pre-made programs ready just yet. I'll have to catch up on that!
Old 12-03-2006, 12:25 AM   #45 (permalink)
blairellis
<>< Jesus Is The Answer
blairellis's Avatar
To whoever posted about the fuel rail/fpr bolts.
The best solution is to ditch the screws all together and get some allen key bolts from Home Depot/Lowes that fit it. They will, next to never, strip out.
Get under that car and start trimming
Blair
93 P10
Old 12-03-2006, 12:48 AM   #46 (permalink)
swiss
swiss's Avatar
Well, today was divorced downpipe test fit round 2. The goal was to determine if it would work if the AC bracket was modified. I decided to yank out the bracket and see what happened.
And here’s what happened:
Success
Look at how beautifully this thing fits:
This was of course with the compressor well out of the way.
The bracket trimming will definitely get past one hurdle. Now I need to figure out how to run the AC lines. The plan for now will be to run the 3” Hass downpipe on the factory j-pipe. I’ll pick up some spare AC lines and mess around with them once the car is up and running.
Old 12-03-2006, 02:12 PM   #47 (permalink)
OneSlow1.6
1.6->sr20de-t
Trader Rating: 26 (100%)
love the write up. thanks!
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers...
99 G20T, black on black, only 1000 miles, 5 spd- daily driver
OneSlow1.6 is offline   Reply With Quote
Old 12-03-2006, 04:01 PM   #48 (permalink)
wes
712 ways to be a dick!
Trader Rating: 23 (100%)
Do you know specifically where the pipe hits the bracket? I would mark it and see if perhaps someone can fab you up a new bracket that avoids the problem area. This will save weight as well!
my site
Old 12-03-2006, 04:10 PM   #49 (permalink)
Octave236
like a stray puppy
custom aluminum bracket FTW
Old 12-05-2006, 11:57 PM   #50 (permalink)
swiss
swiss's Avatar
Yeah, it's just the top right corner:
I'm thinking something like this photoshop would work well:
Here's the original for reference:
A new custom bracket would be nice, but I think this will do.
Old 12-06-2006, 12:02 AM   #51 (permalink)
budsang1
Beware....THE BEAR!!
budsang1's Avatar
Trader Rating: 31 (100%)
not to mention that corner was probably 5lbs, lol, damn that bracket was heavy...you would think a much more light weight bracket could of been used
budsang1 is offline   Reply With Quote
Old 12-06-2006, 12:07 AM   #52 (permalink)
wes
I remember bob legere back in the day drilling a ton of holes in the bracket to save weight! Like I said I cut mine more than in half and it saved over 5 lbs....
I went through 5 18V batteries in the sawzall and 3 blades trying to get through it though.... I guess what I am trying to say is use a bandsaw!
Old 12-06-2006, 10:52 AM   #53 (permalink)
Octave236
like a stray puppy
do it... do it... do it...
Old 12-06-2006, 10:57 AM   #54 (permalink)
Octave236
like a stray puppy
swiss i know a buddy thats an hvac certified guy so if you need some custom lines made just let me know... i bet he wouldnt mind at all. a few buck maybe but nothing like spendin 300$ on custom lines at a mechanic...
Old 12-06-2006, 10:34 PM   #55 (permalink)
swiss
swiss's Avatar
Sounds good, he is in Nashville?
Old 12-06-2006, 10:37 PM   #56 (permalink)
swiss
swiss's Avatar
Studs
While everything was apart, I wanted to replace the manifold studs (the ones in the cylinder head) and j-pipe studs. Both are very prone to breakage. I’ve broken them before, and it sucks pretty bad.
Here’s the new goods:
There are tools you can buy to change studs, but I’ve never used one. Short of using a special tool you have two basic options.
Option one, the double-nut method, takes a little practice, but it’s pretty simple. Put a nut partway down on the stud; tighten another nut down on top of it.
Because you want to remove the stud, you’ll turn the bottom nut. The top nut will hold it in place, so instead of the nut turning, the whole stud turns.
To install a stud, you turn the top nut instead.
That worked for ten out of the eleven studs I replaced. The last one required option two, brute force:
All manifold studs removed:
While the studs are out is a great time to prep the head for a new gasket. Half the old gasket is usually still stuck to the head. I used a plastic putty spreader to scrape off the old gasket residue. You don’t want to use anything that could damage the aluminum.
Some “staining” is normal from the OEM gasket. Just be sure that the mating surface is perfectly smooth.
Here are the new manifold studs installed:
I ran into some trouble on the j-pipe studs. I read that the j-pipe studs were the same as used for the manifold (M10x1.25). Sure enough, the 10x1.25 nuts threaded right on. The first two studs came off without incident. I had to get medieval on the last one with vice-grips, but no big deal.
Then I started to turn in the first stud (the hole I got medieval on). It didn’t really want to go, but I thought it just needed a little encouragement. I forced it a couple of turns before it started to feel really wrong. I backed it out and saw it was starting to chew up the threads. It took me forever to figure out what was going on… the original stud was two totally different threads! The “anchor” end was M10x1.5 and the “nut” end was M10x1.25. WTF?!
I picked up a tap from NAPA to clean up the threads, and I tried to find a stud like it. I checked with just about every parts store in town and even looked online, but couldn’t locate one. I ended up just buying some M10x1.5 studs and some new nuts to match.
Old 12-06-2006, 10:39 PM   #57 (permalink)
swiss
swiss's Avatar
Gaskets
The old exhaust manifold gasket was pretty well destroyed:
I picked up a nice metal 3 layer Nissan gasket to replace it:
The turbine gaskets were in great shape, so I just cleaned them up a bit. These nice metal gaskets last for thousands and thousands of miles:
The old downpipe gasket was OK, but look at the soot line:
As it turns out, the j-pipe has a 2.75” outlet. A 2.5” gasket blocks part of the opening. I picked up a really nice 3” aluminum gasket. It was perfect for my downpipe, but it wouldn’t fit over the j-pipe studs. After looking at it for a minute, I realized I could bore out the hole and make it work:
Perfecto.
Old 12-06-2006, 10:41 PM   #58 (permalink)
swiss
swiss's Avatar
EGT Sensor
I needed to modify the manifold heatshield to accommodate the relocated EGT sensor.
After I picked the spot, I drilled out a hole. I started small and worked my way up to a 1/2” bit, then used a reamer to get it to the appropriate size (~1”). Finally, I cleaned up the hole with a round file and some sandpaper.
Sanded down and prepped:
And finally with a few coats of VHT flameproof:
