Old 12-06-2006, 10:53 PM   #61 (permalink)
swiss
swiss's Avatar
Trader Rating: 20 (100%)
Downpipe
Since I'm sticking with the stock j-pipe for the time being, I had to get the Hass downpipe ready for action. I took it down to a muffler shop today and had the O2 bung welded in and the top "dimpled" for wrench access.
Say, what's all that beautiful stainless steel in the background?
BTW, I read about that dimple thing here:
http://www.sr20forum.com/showpost.php?p=1595588
It works like a charm.
I also got the manifold, turbo, and j-pipe bolted back on the car today.
Old 12-06-2006, 11:31 PM   #62 (permalink)
swiss
swiss's Avatar
Originally Posted by t bags
whats the part# on the manny gasket...great work also looks like fun
I already threw the bag away, but I got it on ebay. Here's my auction:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=001&sspagename=STRK%3AME WN%3AIT&viewitem=&item=110058732221&rd=1,1
I was going to get the B15 metal gasket, but it was backordered through Nissan. The auction said this one is from an S14, but it's probably the same thing. It looks like I got his last one for now. He also sells a five layer version:
http://cgi.ebay.com/ebaymotors/NISSAN-SR20DET-S15-240SX-METAL-EXHAUST-MANIFOLD-GASKET_W0QQitemZ8064768904QQihZ019QQcategoryZ33666 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Old 12-12-2006, 09:16 PM   #63 (permalink)
swiss
swiss's Avatar
Solid Dogbone
I picked this up a while ago:
I actually installed it a while ago too, but I’m just now getting around to posting it.
Sorry for the sorry pic.
Old 12-12-2006, 09:18 PM   #64 (permalink)
swiss
swiss's Avatar
Intercooler
While I had everything apart, I was going to redo the hotside intercooler piping. My primary reason was because it was so damned difficult to take apart. I didn’t like having to take the front end off of the car just to take out the manifold and turbo.
After thinking for a while, I decided against it. One of my future projects will be a radiator upgrade. I’ll be converting the fans to pushers as well. With the fans out of the way, the piping won’t be an issue.
I did decide to freshen up the intercooler’s flat black finish. It had apparently eaten its share of highway debris, and it was starting to look pretty beat up.
Before
After
Old 12-12-2006, 09:21 PM   #65 (permalink)
swiss
swiss's Avatar
VRS Exhaust
I picked up this 3” VRS many months ago (it’s a full cat-back, I just didn’t take a picture of the rest of it).
I decided to give the can some VHT Flameproof to tone down the look a bit.
Masked off:
My “paint booth”
Here’s the full setup:
This is the 3” test pipe I picked up on ebay:
In that picture it was already partially bolted together. I test fit everything together a few weeks ago, before I took the car apart. The install was super easy. I did have to cut about an inch off of the mid-pipe and trim the u-clamp studs, but no major complications.
While a lift would have been ideal, I made do with a couple of jacks and jackstands:
It’s not exactly roomy, but I’m about 5’11” 250lbs. If I can do it, you can do it. Also notice the old blanket. I moved it around under the car where I was working to keep the exhaust from getting scratched up.
I already had the downpipe bolted up.
Then I put the axle-back in place.
Next I put in the mid-pipe. I started with the hanger and loosely connected the ends.
After everything was in place, I tightened it up. Here’s the finished product:
I’m really happy with it. It sounds great and looks great too. It does clank around once in a while, but I’m going to try out a set of Kartboy Exhaust Hangers to see if that will keep it in place:
http://www.sr20forum.com/reviews/***.../cat/11/page/1
Old 12-12-2006, 09:28 PM   #66 (permalink)
swiss
swiss's Avatar
And that is pretty much that for now. Everything is back together for the time being.
Here's a good shot of the EGT gauge through the heat shield:
I'm going to take a break for a while, but I'll be back soon.
Old 12-12-2006, 09:38 PM   #67 (permalink)
91civiceater
Classic is Classy
if the kartboy hangers dont work, i picked up solid rubber hangers off of a ford pick up. They work great for me. no clanking or stretching.
91 Se-R: black, JDM DE, Emanage Ultimate, JWT S4's, UR 2 pullie set, HS CAI, SSAC header, Mandrel 3in Magnaflow exhaust, fidanza flywheel, exedy clutch, Walbro hp 255lph pump, Nismo afpr, ES motor mount inserts, ES hyperflex kit, Hyperco gen2 springs, KYB agx's, Motegi RT5's 13.5lbs!!!! t3/t04e to come
14.701 @ 93.51 N/A
91civiceater is offline   Reply With Quote
Old 12-12-2006, 10:21 PM   #68 (permalink)
turco
that muffler looks awesome black. I might have to steal that idea. The car looks great btw!
2000 Black Sentra SE w/aPP
turco is offline   Reply With Quote
Old 12-12-2006, 10:21 PM   #69 (permalink)
budsang1
Beware....THE BEAR!!
budsang1's Avatar
Trader Rating: 31 (100%)
everything is looking awesome swiss!!
budsang1 is offline   Reply With Quote
Old 12-13-2006, 11:06 AM   #70 (permalink)
Octave236
like a stray puppy
x2
1993 NX2000: Weekend fun car
1990 Accord: New to me Daily Driver
Octave236 is offline   Reply With Quote
Old 12-13-2006, 01:08 PM   #71 (permalink)
wes
712 ways to be a dick!
Trader Rating: 23 (100%)
What happened to the divorced downpipe? Ditch that idea for now?
Car and mods. look great BTW!
my site
Old 12-13-2006, 03:38 PM   #72 (permalink)
blairellis
<>< Jesus Is The Answer
blairellis's Avatar
Heatshield turned out awesome. I like how you went with the allen key bolts as well. Less prone to breaking off like those aweful bolts Nissan used in the first place.
IMO, the only thing left to do is for you to pull the VC and put some time in at your paint booth with it.
Blair
93 P10
Old 12-13-2006, 03:57 PM   #73 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 40 (100%)
Doing great work there man, I like the painted muffler and the modded heatshield for sure! Very nice!
Brent
Old 12-13-2006, 06:07 PM   #74 (permalink)
swiss
swiss's Avatar
Thanks everyone.
The divorced downpipe will be on that car. I gaurantee it. I'm still trying to determine my best course of action for the AC. I could...
a) Run custom AC lines and trim the AC Bracket to run the downpipe.
Keep AC, gain divorced downpipe, lose money, lose time.
b) Yank out the lines, condenser, bracket, and compressor to run the downpipe.
Lose AC, lose about 40lbs, gain divorced downpipe, gain real estate in the engine bay, gain better airflow to the radiator.
I just wanted to put everything back together while I figure out what exactly I'm going to do. I'm probably going to remove the AC. It seems like a pretty attractive option, especially considering the car logged less than 3,000 miles this entire year. If it's that damn hot outside I can drive the 200sx.
I'm also going to take the time to clean it up, get it flanged, and get a nice ceramic coating for it.
Old 12-13-2006, 06:13 PM   #75 (permalink)
swiss
swiss's Avatar
Yeah, the original bolts were rusted badly of course. When I was poking around the bolt at Autozone I found those and thought they'd be a nice touch.
When I get some cams I'll definately take care of the valvecover.
Old 12-14-2006, 01:24 AM   #76 (permalink)
JTM
My sister is JDM, I'm JTM
Great write-up and pics I enjoyed every picture and every word. You must have a lot of patience when you begin a job. I alway start out with the best intentions and then wind up rushing though and regretting it down the line. I look forward to seeing more on your project.
1994 Eagle Summit ES 5-spd
1996 Dodge Caravan
1996 Nissan B13 Sentra
http://www.cardomain.com/id/JTM204
JTM is offline   Reply With Quote
Old 12-14-2006, 08:28 AM   #77 (permalink)
chipey23
Boost Addict
chipey23's Avatar
Keep the A/C man, you can do it. Even if you have to get custom ones made.
SR20DEEP__BIT BY THE VVL BUG!!
chipey23 is offline   Reply With Quote
Old 12-14-2006, 08:41 AM   #78 (permalink)
