Old 03-22-2007, 07:21 AM   #101 (permalink)
XxToKeSxX
XxToKeSxX's Avatar
Trader Rating: 42 (100%)
oh you son of a bitch! you trying to keep on the low w/ a cam install????
I love this thread, so well documented... and your inspiring me to go with a pusher setup. I have an a/c compressor on the bluebird, but didn't have one n/a/// but I just realized I don't have the condensor and any of the lines! off with it, rocking the no A/C again!
1998 SE-R | S3Rs/I/H/E/M | 99.9% Daily Driver | Rubí DeL FuegO
1993 NX-? | Have No Clue | 00.1% Daily Driver | The Diable-Bleu
1991 nX-T | My Boost Slut | 00.1% Daily Driver | The Deviled Egg
Shift_from a Sentra, and got Scrambled Eggs
Old 03-22-2007, 07:53 AM   #102 (permalink)
Sigfod
Sigfod's Avatar
I am almost tempted to pull my A/C. But it is so close to working again.
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2006.5 2006.5 GTI DSG 2.0T FOR SALE
2008 BMW 328xi Touring
2008 BMW 328xi Coupe
Sigfod is offline   Reply With Quote
Old 03-22-2007, 08:42 AM   #103 (permalink)
dmp316
200 whp club
omg Swiss i really give you man props for this informitive thread, and your hard work.
Damien
Sentra 2k
94 Teg------ DD
95 200sx SE-R.....SR20DET...For Sale
Originally Posted by ninetails View Post
but yeah.. there are some jamaicans that cant stand hatians
trini's are usually jealous of jamaicans
dmp316 is offline   Reply With Quote
Old 03-22-2007, 09:02 AM   #104 (permalink)
turco
Yeah dude those alt pivot bolts SUCK!!!
2000 Black Sentra SE w/aPP
turco is offline   Reply With Quote
Old 03-22-2007, 10:37 AM   #105 (permalink)
Sigfod
Sigfod's Avatar
What, have you broken one too? I did on my RR.
Old 03-22-2007, 10:55 AM   #106 (permalink)
civicdragon
BTCC VE Power
Trader Rating: 16 (100%)
can wait til its done, your gonna love it
KL0 P11 Sport
Surround Sound
My VE thread
Old 03-22-2007, 12:27 PM   #107 (permalink)
Sigfod
Sigfod's Avatar
Were all gonna love it!
Old 03-23-2007, 12:53 AM   #108 (permalink)
swiss
swiss's Avatar
Trader Rating: 20 (100%)
Thanks guys.
Originally Posted by rocket View Post
hey what kind of fans and part numbers, i have one, but i need to know if it's the correct one.. and of course i need the other little one.. by the way thanks for the intercooler pics, i got some weird set up to keep my a/c and such.. thanks again
They are FAL Slim Fans. I don't know the part number.
If you're not going to put a condenser in it, get rid of that shiz! The compressor and bracket together weigh like 25-30lbs.
Old 03-23-2007, 12:58 AM   #109 (permalink)
swiss
swiss's Avatar
A/C Delete and Pusher Fans/ Divorced Downpipe
Last weekend I tested out the fans, everything worked perfectly. So I put the front end back together and took it for a spin. All is well. I stayed nice and cool.
I also dropped the divorced downpipe off at the machine shop for a few finishing touches. It should be done Saturday.
Old 03-23-2007, 01:00 AM   #110 (permalink)
swiss
swiss's Avatar
JWT S3R Cams
With a Roller Rocker engine my cam choices are pretty limited, but I’ve heard nothing but good things about the JWT S3R cams. I picked some up from a forum member who was returning his B15 to stock:
I’m not going to go into much detail, but I’ll show the pictures I took along the way. There are already lots of great write-ups on cams, here are two really good ones:
http://www.geocities.com/n_dahi/cams/cams.htm
http://jimwolftechnology.com/wolfpdf...NSTFORSR20.PDF
The two are a little different, but there’s good information in both.
When I drained the oil and popped the valve cover, I was very pleased with how clean the engine was:
Apparently when the engine was swapped, they moved the chain guide from the old motor over to this one. I threw it in the trash for weight reduction. Nissan did away with the chain guide in 1998.
Here are some better shots inside the head:
Here are the “rollers” for which this engine is named:
This isn’t the engine’s original valve cover, but it was very clean as well:
I set the engine to top dead center, zip-tied the timing chain, and removed the distributor:
Next I removed the timing chain tensioner. Newer SR20 engines have an updated version of the tensioner:
Neither write-up above recommends removing the tensioner, but I think it’s easier than trying to “work around it.” Here’s a good link for info on the tensioner:
http://www.se-r.net/zotz/se-r_tensioner.htm
Also here’s a good tip my Dad taught me long ago- Keep some of these fastener assortments around (you should have a few of these anyway):
When you are removing multiple parts simultaneously, keep the hardware for each item in place using fasteners from the kit:
That will help you avoid losing nuts and bolts, and also help you avoid getting them mixed up.
Old 03-23-2007, 01:02 AM   #111 (permalink)
swiss
swiss's Avatar
JWT S3R Cams
Speaking of getting things mixed up, here’s the template to keep track of my cam caps:
Here is a shot of everything removed:
Comparing the stock and JWT cams:
I picked up all new gaskets and a distributor o-ring:
I also decided to get something nice to cover the cams. I had this powdercoated by Late Night Custom:
I picked up this oil cap on Ebay. I must say, I’m pretty impressed for under $10 shipped. It’s made by Mr Gasket and it’s CNC machined aluminum.
Here everything is coming back together:
All buttoned up:
After I had everything reassembled, I reset my timing to 15*. Here’s some info on how to set ignition timing:
http://www.geocities.com/n_dahi/timing/timing.htm
The idle has a little burble to it, but it’s not extreme. Idle sounds great, WOT screams. They shift the power band upward which makes first gear much more manageable, then the top end comes on really strong. I’m very happy with them.
Old 03-23-2007, 01:44 AM   #112 (permalink)
gomba
Endless Turbo Preparation
A quality setup and install. A template many of us should follow. Very clean and thorough job.
'95 200sx SER - Loading Turbo.exe |!!!!.................| 22%
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
gomba is offline   Reply With Quote
Old 03-23-2007, 11:21 AM   #113 (permalink)
Octave236
like a stray puppy
Looks great Swiss. Wish mine was running again.
1993 NX2000: Weekend fun car
1990 Accord: New to me Daily Driver
Octave236 is offline   Reply With Quote
Old 03-23-2007, 06:38 PM   #114 (permalink)
swiss
swiss's Avatar
My DSM BOV works pretty well, but I still occasionally get compressor surge coming out of light throttle. I needed something that was adjustable, could be recirculated, and would work well with modest boost levels. I decided on a Greddy Type RS:
I rented a vacuum hand pump from AutoZone to adjust it:
I adjusted it following these directions:
http://www.sr20forum.com/showthread....ght=adjust+bov
I set it to begin opening around 8 inHg and it opens very nicely at full vacuum. Out of curiosity, I tested the DSM BOV… it began to open at 15 inHg.
I also picked up the adapter needed to recirculate it:
I’m waiting for my flange to arrive. The one I purchased should be here soon.
Old 03-26-2007, 11:25 AM   #115 (permalink)
Octave236
like a stray puppy
Hmmm thats cool heads up on the DSM BOV. I have one too. Guess I'll do what you did. I kinda wanted an adjustable one. Like you said I have very small surge if I hit like 2psi of boost. I love this thread BTW swiss.
Old 04-10-2007, 08:33 PM   #116 (permalink)
swiss
swiss's Avatar
Greddy RS BOV
In preparation for the new flange, I hacked off the old DSM flange. I intentionally left a “stump” behind so I wouldn’t need to grind down the new flange to match the contour of the pipe.
I forgot to take a picture of the flange by itself, but here it is welded onto the pipe and painted:
Here it is mounted:
It works beautifully.
Old 04-10-2007, 08:35 PM   #117 (permalink)
swiss
swiss's Avatar
That Damn Breather Filter
Next on my lis
