B14 Sentra SE Project - SR20 Forum
Old 06-15-2006, 08:25 PM   #1 (permalink)
working on it
swiss's Avatar
Feedback Score: 27 reviews
I've always liked reading the well documented project threads on this forum. I have a project of my own now, so I thought I’d create a thread for it. From this point forward, I’ll document everything I do here with plenty of pictures and commentary. Here is the car how I got it:
It’s a 1998 Sentra SE that I purchased from a forum member in January. It’s already got quite a few mods, but there is always room for improvement. My performance goals are somewhat modest, I’m looking for 250-275whp. I want a quality setup though. I won’t be half-assing anything, I can promise you that.
Here is the setup as it is now, mostly from the previous owner:
Roller Rocker SR20DE
T25 Turbo
Bluebird Manifold
2.5" Downpipe
Greddy SP Exhaust
Black FMIC with 2" Hot, 2.5" Cold Piping
1G DSM BOV
FAL Slim Fans
JWT ECU- 3 Bar, 370cc, Stock MAF
ACT HDSS Clutch
PS Short Shifter
Hyperco Springs
AGX Struts
Courtesy Front and Rear STBs
Wilwood 11" Brakes Front
Maxima Brakes Rear
SS Brake Lines
Altima MC
Plans for now include:
Full 3” Downpipe/Exhaust Upgrade
FPR/FP Gauge
Fuel Pump
MAF Upgrade/ ECU reprogram
LSD transmission/Axle swap
S3R cams
Intercooler Upgrade
Boost Controller
T28 Setup
I’ll end up adding quite a bit to that. The list above is just the general direction I’m going in, and loosely speaking, the order in which it will be completed. I’m sure I’ll address some cosmetic mods as well, but don’t get too excited. I’ll keep it pretty tame. I’m always open to feedback and suggestions. Please check back frequently.
Update as of March 08:
Old 06-15-2006, 08:26 PM   #2 (permalink)
working on it
swiss's Avatar
3” Downpipe/Exhaust
I purchased this Hass downpipe from a forum member a couple of months ago:
It is for the most part a standard T25 downpipe, but unlike a normal T25 downpipe, it came with a 3” j-pipe flange. The stock j-pipe is 2.5” and won’t bolt up. I knew fabrication was going to be necessary. Rather than downgrade the downpipe to a 2.5” flange, I decided to upgrade my j-pipe. I purchased a RWD j-pipe from ebay (along with some flanges, bungs, a reducer, and misc other supplies) with the intention of modifying it for FWD with a 3” flange.
Shortly after it arrived I stumbled upon a diamond in the rough on ebay. I won this downpipe for $75 shipped.
It arrived yesterday. I immediately had one of the guys on my team check it out.
In a previous post I made (before it arrived), Chriscar had some great suggestions and questions. He noticed that the flange lacked a divider to help ensure wastegate/exhaust flows were adequately separated.
Here is the RWD piece as a reference. Note the extra piece separating the exhaust flow from the wastegate flow.
Also note the divider on the RWD piece can be removed with 2 allen bolts. I’m going to take it off and have a local machine shop replicate it for the new downpipe. I’ll keep you posted on that.
Chris was also curious about the length of the wastegate tube. Apparently 18” is ideal. I used a string to measure. It turned out to be 14.5”. A little short, but I still think it will work great.
Once the divider is welded in, I’m going to cut it just after the wastegate tube re-enters and put a flange on it. Then I’ll cut and flange the downpipe to match. Something like this:
As for exhaust, I’ve got that covered as well, once again thanks to a forum member. It is a 3” VRS cat-back. It will be mounted up after I finish the downpipe.
More updates soon to come.
Old 06-15-2006, 09:21 PM   #3 (permalink)
1.6->sr20de-t
Feedback Score: 26 reviews
very niiiice i love projects!
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers...
99 G20T, black on black, only 1000 miles, 5 spd- daily driver
OneSlow1.6 is offline   Reply With Quote
Old 06-15-2006, 09:30 PM   #4 (permalink)
jp
Excelent congrats.. just one thing...buy a z32 or cobra maf..and 550 injectors.
2001 Nissan Primera GX
560whp at 18lbs Stock VE-t motor.
Chile
jp is offline   Reply With Quote
Old 06-15-2006, 11:02 PM   #5 (permalink)
1.6->sr20de-t
you got that car all the way from texas huh?
Old 06-16-2006, 09:52 AM   #6 (permalink)
born 4 boost live 4 ve
Feedback Score: 15 reviews
i want that downpipe...
was 91 sr20ve-t classic
now 92 sr20ve classic
blackb13se-r is offline   Reply With Quote
Old 06-16-2006, 02:57 PM   #7 (permalink)
working on it
swiss's Avatar
Yeah, she's a Texan. Many people remember this was Spaceman Spiff's car. I just couldn't pass it up. Fresh motor swap, great suspension setup, awesome brake setup, and the car is clean as hell. In my opinion, the car would have been worth what I paid for it without the turbo setup.
I'm definately going with the Z32 MAF, but I've been agonizing over the injectors. As I mentioned above, my goal is only 250-275 whp. The 370's @ 4bar could handle about 290whp.
If I ended up going overboard (nobody ever does that... right?), I'd not only have to get bigger injectors, I'd need to have the ECU reprogrammed yet again. That would set me back an extra $100 or so, plus extra downtime.
On the other hand, if I upgrade injectors now, and never passed my original benchmark... the injectors wouldn't have been necessary after all. That's $300 or so I could have spent on other goodies. Despite the risk, I'm leaning more and more toward just throwing 555's in there and getting it out of the way.
Blackb13se-r, chriscar is the current heir to the downpipe. I'll let him know you're next in line.
Old 06-16-2006, 03:09 PM   #8 (permalink)
GT30R'd Up
Feedback Score: 7 reviews
I Always wanted to have a Sentra SE Turbo Project but a 200SX was all I found when in search for it. Nice Starter Car!
BTW, Can I call first dibs one that Greddy Catback whenever you pull it off to put on that full 3"??
Thanks!
96 SE-R GT30R'd Up
07 G35S Sedan
Nizmonik SE-R is offline   Reply With Quote
Old 06-16-2006, 06:27 PM   #9 (permalink)
i'm talking bout thAT black DIVORCED GATE one, your not gonna use it?
Old 06-16-2006, 08:37 PM   #10 (permalink)
working on it
swiss's Avatar
I'm going to use it and don't really plan on getting rid of it. You never know, though. I might decide 6 months from now to buy a setup that I wouldn't be able to use it on. If I ever get rid of it in the future, Chris said to let him know.
Old 06-17-2006, 09:49 AM   #11 (permalink)
Boost Addict
chipey23's Avatar
Feedback Score: 13 reviews
I Think S4's would be a better choice as cams go. It'll help that T28 breath easier and at proabably less boost to achieve your H.P. goal. Anyway good luck and keep us updated. Everything else looks right on point.
chipey23 is offline   Reply With Quote
Old 06-19-2006, 07:08 PM   #12 (permalink)
working on it
swiss's Avatar
Nizmonik- I'm actually going to use the Greddy on my other B14.
chipey- I'd love some S4's, but it's a roller motor. S3R is the only option.
Old 06-19-2006, 07:15 PM   #13 (permalink)
working on it
swiss's Avatar
3” Downpipe/Exhaust
Today I dropped off the downpipe at the machine shop.
After talking to my guy down there, it wouldn't be cost effective to recreate the separator piece. I am going to sacrifice the RWD dump and have them use the separator off of it instead. It is supposed to be done tomorrow, but I'll be tied up with work. I'll be picking it up on Friday.
Old 06-20-2006, 02:20 AM   #14 (permalink)
nice turbo back!
"A couple of Nissan Sr20's will pull a premium one week before race wars." (Johnny Tran, fast and furious) LOL
420sxDET is offline   Reply With Quote
Old 06-20-2006, 09:44 PM   #15 (permalink)
Veritas
SERprise In WV's Avatar
Feedback Score: 17 reviews
Looks good. Can't wait to see the intercooler upgrade.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
Old 06-22-2006, 01:41 PM   #16 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
Great to see another member do a write up! I like following along on projects!
Brent
1999 SE-L -- back to NA form
Old 06-22-2006, 07:18 PM   #17 (permalink)
working on it
swiss's Avatar
It's pretty far down my list, but things are about to start moving quickly. Maybe I can get to that soon.
Thanks for your support guys.
Old 07-02-2006, 08:38 PM   #18 (permalink)
working on it
swiss's Avatar
OK, I've got a few updates.
I got the dump-pipe back from the welder and all looks well. I need to figure out now where I want the O2 bung and have it welded in. I also need to take off the manifold and tap it for EGT. The current setup has it in the downpipe and I don't really care for that.
I've been tearing the UPS man a new @sshole this week. He's had to stop at my house almost every day.
I'll be upgrading the fuel system before I finish the downpipe. Running the stock fuel pump is really sketchy, as it's only good to about 190whp. Once I have this stuff in, I should have about a 250whp ceiling (limit of MAF and injectors). That should be fine until later on, then they will be upgraded too. I'm still waiting on the T fitting for the FP gauge. I hope it arrives tomorrow so I can knock this sh*t out before I have to go back to work.
Not pictured, I also picked up some Redline Shockproof Heavy. I've been running it in my daily 200sx for a while, that stuff is the sh*t. Hopefully it'll make my non-LSD gearbox last forever ... or at least until I get an LSD tranny for it.
I know there are more interesting projects than mine. Thanks for taking time to check mine out.
Old 07-02-2006, 09:16 PM   #19 (permalink)
1.6->sr20de-t
nice...running the same fuel pressure gauge kit as me and serban ehh?
Old 07-02-2006, 10:29 PM   #20 (permalink)
BTCC VE Power
Feedback Score: 16 reviews
looks great, i miss my b14 and being boosted
KL0 P11 Sport
Surround Sound
My VE thread
