Nissan W10 & W11 SR20DET Avenir Facts - 2007 - Page 5 - SR20 Forum
Old 08-27-2009, 11:02 AM   #81 (permalink)
Here it is: 22680-54C00.
Ing. is offline   Reply With Quote
Old 08-27-2009, 11:03 AM   #82 (permalink)
Originally Posted by Ing. View Post
I will get the MAF number tonight and i will post it. My friend has the DET MAF.
Here it is: 22680-54C00. According to the follow Info (Excuse me but i don`t remember who post it and where i find it, i just copy and paste to MS Word), it is a Bluebird U13 91-93 MAF.
SR20DET MAF LIST AND ECU LIST
________________________________________
SKINNY O2 SENSORS:
89/10 - xx/xx U12 SR20DET - MAF 22680-79E00
89/10 - 90/09 ECU 23710-79E00 M/T
90/09 - xx/xx ECU 23710-79E01 M/T
89/10 - 90/08 ECU 23710-79E10 A/T
90/08 - xx/xx ECU 23710-79E11 A/T
89/10 - 90/10 ECU 23710-79E60 M/T
90/10 - xx/xx ECU 23710-79E61 M/T
*o2 sensor - 22690-79E00 (Skinny Type)
*o2 bung - 20607-V5000 (Skinny Bung)
91/09 - 95/01 U13 SR20DET - MAF 22680-54C00
95/01 - xx/xx U13 SR20DET - MAF 22680-54C01
91/09 - 93/08 ECU 23710-1E000 M/T
91/09 - 93/08 ECU 23710-1E010 A/T
93/08 - xx/xx ECU 23710-4E600 M/T
93/08 - xx/xx ECU 23710-4E610 A/T
*o2 sensor - 22690-1E001 (Skinny Type)
FATTY 02 SENSORS:
08/90 - xx/xx B13 SR20DE - MAF 22680-53J00
*o2 sensor - 22690-64Y12
*o2 bung - 20607-P6500
95/08 - xx/xx W10 SR20DET - MAF 22680-54C01
95/08 - 97/01 ECU 23710-95N11 A/T **
97/01 - xx/xx ECU 23710-95N15 A/T
*o2 sesnor - 22690-91N00 (Fatty Type)
*o2 bung - 20607-P6500 (Fatty Bung)
98/08 - 00/05 W11 SR20DET - MAF 22680-54C01
98/08 - 00/03 ECU 23710-WA310 A/T
00/03 - 00/05 ECU 23710-WA311 A/T
00/05 - 00/09 ECU 23710-WA720 A/T
00/09 - xx/xx ECU 23710-WA721 A/T
*o2 sensor - 22690-5V420 (Fatty Type)
**This is the DET ECU that i want to install.
Do you think that use Bluebird MAF with a Avennir ECU is my problem?.
Yesterday i received an Z32 MAF from E-Bay. Do you think that if i change the DET Bluebir MAF for a Z32 MAF to use with the Avennir ECU, and i set up the E-Manage Blue to use with Z32 MAF, it will resolve the problem.
Sounds a kind of obvious, but i don`t have experience with this problem in my car, and actually and don`t want to cut the MAF Harness to make the swap, without success answering my interrogation.
Old 08-28-2009, 08:08 AM   #83 (permalink)
CAR SLÜT
The 54C00 MAF is also identical to the GTiR MAF(same part number)
The W10 MAF is 54C01 and the ONLY difference is that the wiring plug is different, W10 plug is same as the B14/N15 style MAF plug.
Set your distributor top bolt to the middle of the slot, cause my guess is your timing is out and I am betting you advanced the base timing a little to get the DE ECU to run with the DET motor.
I always prefer to solve every problem before creating a new one but if you think the Z32 will 'fix' the problem then by all means try it
Also, you may have to consider that the W10 ECU you have could also be damaged.
N14 Pulsar - FWD VQ35DE, Altima HLSD 6spd, QM Twin plate clutch, 12.7:1CR, Kelford C spec cams, OBX extractors, 3" exhaust, Bikirom VQ30 ECU & 18" Murano wheels
Pics
Smashed VY TT LS1 SS Ute: Pics
US Domestic muscle in transit...
iamhappy46 is offline   Reply With Quote
Old 08-28-2009, 11:10 AM   #84 (permalink)
That´s right. Past days i wanted to connect an Avenir MAF but i didn`t because the plug was B14 Style, not B13. I didn`t know that are exactly the same MAF internally. That`s new for me, thank`s.
I set my distributor to 15ş a few days ago, but i will doble check it, is not a bad idea.
The N62 MAF was an upgrade that i allways want to do even before than a ECU Swap. So, with or without de DET ECU, yesterday i installed.
I hope reduced the problems, but i`m not sure if it wiil be.
I will connect the Avenir ECU this weekend with de Z32 MAF. I will post the results of this Combination. I will pray
Old 08-30-2009, 08:16 PM   #85 (permalink)
GA16 Baby
good info here...bump
liljay781 is offline   Reply With Quote
Old 08-31-2009, 11:39 AM   #86 (permalink)
Z32 MAF Installed. Unfortunately my car can`t start. I connect the Avenir W10 with the Z32 MAF. I think that, there´s a electric problem, cause a have 1 code in the ECU (Ignition Signal).
Avenir ECU + Z32 MAF + E-MANAGE BLUE **ADVICE**
For all people that want to set the Z32 MAF with the E-Manage Blue, you have to set the Piggyback (by Software) with the NS-HW2 Maf type (Known: 300zx), and you have to Set your Internal E-Manage Rotary Switch (by Hardware) with this combination: 2-0-6 (Unkown).
The E-Manage Manual don´t have the Avenir Engine rotary switch combination, but i read the Apexi S-AFC2 Manual, and with so much info available of engines, i found the Avenir Engine and use exactly the same setting of MAF that use the Nissan Silvia S14. This last one is in E-Manage Manual, so, i made an analogy and set the same rotary switch combination (2: "1 Coil Distributor", 06 "Avenir Main Unit ECU"). Voila... the Analog Output of the E-Manage Blue, marks 0.6 V (the same one that an Avenir MAF), this means, that the setting that i choose, was correct
Old 11-09-2009, 01:15 PM   #87 (permalink)
bump........
srb13 is offline   Reply With Quote
Old 11-09-2009, 07:41 PM   #88 (permalink)
agent camel toe
Feedback Score: 22 reviews
avenier
nyce1s.com
R.I.P. RESPECT SR.
96 b14 det--under the knife
2002 quest gxe--pimp wagon
Old 10-21-2010, 01:26 AM   #89 (permalink)
Got Boost
baught an avenir..has a complete red valve cover. turbo clocked down.
ShawnyBoy is offline   Reply With Quote
Old 10-24-2010, 01:37 AM   #90 (permalink)
Got Boost
[IMG][/IMG]
Old 10-24-2010, 01:38 AM   #91 (permalink)
Got Boost
[/IMG]
Last edited by ShawnyBoy; 10-24-2010 at 01:39 AM. Reason: mistake. picture didnt show up
Old 01-13-2011, 05:31 AM   #92 (permalink)
Endless Turbo Preparation
Feedback Score: 6 reviews
Sorry, not an Avenir..a blue bird. Unless VC was painted red.
Check turbo part #, it's the only way to tell for sure.
-G
'95 200sx SER - W10+GT2871R_15psi+S4.exe loaded successfully! (Daily Driven )
Member of the 1st Temporalist Church of KC -Zip Tie Ritual temporarily each Sunday.
“He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
gomba is offline   Reply With Quote
Old 04-20-2011, 02:39 PM   #93 (permalink)
Lurker
When you mention that the W11 uses a lowport oil filter, is that just referring to the threading on the mount and the filter number itself, or is the oil filter located in a different spot on the engine than the W10?
NelsonPeeTen is offline   Reply With Quote
Old 04-20-2011, 08:05 PM   #94 (permalink)
El Lobito with many toys
Wolf_SER's Avatar
Feedback Score: 24 reviews
I have owned both W10 and W11 and both use Highport Oil Filter.
Wolf_SER is offline   Reply With Quote
