im newb i need help running rich!! - SR20 Forum
Old 10-19-2007, 11:07 PM   #1 (permalink)
hey guys im running very rich and my car seems to die when i enter boost my vacuum is around 10 :/ pretty low i think.... *** has rough idle *** of this just a add in idk if this adds anything but could it be a open bov also when i turn on the ac the car acts really funny wants to die and vacuum lowers and highers it just acts funny and there is a loud sound sorta likea a cold air intake sucking in air but louder when i have ac on.. is this normal....need help suggestions also to mention when car what running good the couplers for the intake blew off i put it back on blew off on intake coupler only when i push it to higher boost
Blimpy is offline   Reply With Quote
Old 10-20-2007, 08:09 AM   #2 (permalink)
love the Florida sun!!
Does it break up at a certain rpm range? Have you pulled any codes from the ECU?
Do you see black smoke pour out the tail pipe? Whats your vacuum at idle with the A/C off? It should be around -18 to - 20.
Need more info to help with your problem.
94 Sentra SE-R, 10:1 Red Top SR20DE, ! 15.652 @ 87.34 mph....***Dead***
94sentraSER is offline   Reply With Quote
Old 10-20-2007, 10:31 AM   #3 (permalink)
yes it break up at rpms no i havent read the codes... yes rich black smoke pours out from exhaust im bretty sure its -10 at idle
Old 10-20-2007, 10:34 AM   #4 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
You're not recirculating your BOV? There's your problem.
Old 10-20-2007, 10:35 AM   #5 (permalink)
chriscar's Avatar
Also - moved thread to the Turbo section.
Old 10-20-2007, 10:40 AM   #6 (permalink)
chriscar's Avatar
Read this - http://www.sr20forum.com/turbo/21521...lly-drove.html
