NOOB with question - SR20 Forum
Old 11-07-2007, 06:55 PM   #1 (permalink)
NOOB with question
I'm just looking for some honest opinions here. would someone be better off taking a regular SR20DE and adding an aftermarket turbo set up or buying an imported SR20DET? The DE is fresh off a rebuild to factory specs, no big dollar rods or pistons or rings just what Nissan said the DE should be built to.
BigMoLes is offline   Reply With Quote
Old 11-07-2007, 07:02 PM   #2 (permalink)
Nissan Mut Car...
Feedback Score: 8 reviews
Dependes on compression ratio's, luck in a jdm engine being good.... many factors.
Search man!
Chris Gault
1995 B14 Turbo 200sx SE-R
"You might think your hot sh*t in a champaign glass, when your really just cold diarrhea in a Dixie cup...."
NaLLa8705 is offline   Reply With Quote
Old 11-07-2007, 07:03 PM   #3 (permalink)
fu*k Your Vtac
Feedback Score: 7 reviews
i would search about it, but if you buy a det heres the advantages.
-oil squirters
-lower compression 8.5:1 instead of 9:1, you can use 9:1 and have a nice motor just have to have nice tune.
-already has oil/water lines, dont have to tap for drain.
-the cams in the det are deT cams, designed for forced induction.
-block is built for boost. ive seen 2 de's go bad, one jdm and one US, both were setup right and when broken down had blown ring lands
cons
-cost, ecu, swap, sensors, possible bad engine
93 SE - 91 Front and Rear, Se-r Interior, JDM SR20, 626 Front Lip, Accord Rear Lip, WAI, 3", Cherrybomb dumped in Cats Location, SSR W. 195.50.15' Narni's, Sportlines. Traded.
93 NX2k - Electric Blue, sportlines, axg, prothanes, all new bushings, sr20ve, 3" to N1, WAI, Soon **N1 Cams, Calum ECU, Apexi SAFC2.
Current
NoLmit-B13 is offline   Reply With Quote
Old 11-07-2007, 07:04 PM   #4 (permalink)
SR powered S13 coupe
McCoy's Avatar
Feedback Score: 78 reviews
Option #1 of course. That's looking at it from overall cost and time to do the work. Bolting a turbo kit onto a SR20DE takes alot less time than doing a motor swap.
This topic comes up every few months and there are pro's and con's to both... just do some reading through the turbo section to get a better idea of what it takes to do both.
www.jgstools.com
www.nissanroadracing.com
Old 11-07-2007, 07:07 PM   #5 (permalink)
McCoy's Avatar
-oil squirters
cons
Um, the stock DE is 9.5:1, not 9:1.
The DET cams are nothing special... small if anything. The stock DE cams are an improvement over the DET cams if anything. Don't forget adding JWT S3 or S4 cams to a boosted SR20 does amazing things for the topend... and they weren't designed for a deT as you put it.
Regarding your block is built for boost, and the DE will fail comment... sounds like user error. I've had two, no three setups over the past 5 years that were DE motors turboed and none of them failed. I also track my car on a monthly basis... which is more than most do with a boosted SR.
Old 11-07-2007, 08:37 PM   #6 (permalink)
I need money!
If you are planing on something like a T25 or a T28, i say just go for one of the turbo kits available on classified section of the forum, and give some boost to the DE if its on good condition. Its cheap and the DE holds perfectly.
I would buy a DET if I want to boost more and use a bigger turbo without messing with the internals.
For a hardcore turbo setup changing internals, well is not worth at all to get a DET IMHO, since you are changing almost all of what makes it a DET for aftermarket parts.
1991 Black SE-R, Built SR20VE-T
SR20CR is offline   Reply With Quote
Old 11-07-2007, 08:58 PM   #7 (permalink)
i would go with a already turboed motor if you have the lack of turbo kit building\installing expierences
GT2876RBLUBIRD is offline   Reply With Quote
Old 11-07-2007, 10:16 PM   #8 (permalink)
Feedback Score: 4 reviews
I had both options at my feet, and I chose to turbo the DE I already have.
Old 11-08-2007, 12:02 AM   #9 (permalink)
det are already boosted, designed for boost, have the application design for boosting. it will be less of a aggravation going with a motor already boosted
Old 11-08-2007, 12:33 AM   #10 (permalink)
McCoy's Avatar
that's what the 't' stands for... doesn't mean the SR20DE can't handle boost though.
It will cost more initially. Then there's the unknown is the sr20det you just got have any unknown issues, will it spin a bearing within the first 100 miles of driving it.
The motor he has is running already... one less thing to worry about
Old 11-08-2007, 02:07 AM   #11 (permalink)
SE-R Newbie 4-life
Feedback Score: 21 reviews
the main thing I have to add is assuming this is a FWD you can get a complete det for around the same price as turboing the de, and if you get the ecu you don't have to worry about tuning also if it blows you have the de waiting
gtlaw is offline   Reply With Quote
Old 11-08-2007, 08:36 AM   #12 (permalink)
Done.
Feedback Score: 27 reviews
Not really. That's a generalized statement. I went boost for under $1200. You buying a DET is going to cost you that, then you still have to pay shipping costs.
SR20DEEP MD
12 Subaru Legacy 2.5i Premium
04 Subaru WRX 'goon
Cliff is offline   Reply With Quote
Old 11-08-2007, 11:08 AM   #13 (permalink)
i say it depends on what kinda turbo kit you are building if you are building for budget than it could be cheaper if you are building for performance\relieability than i say a turbo kit can run you more than a complete turbo motor
just depends
Old 11-08-2007, 11:17 AM   #14 (permalink)
Done.
just depends
What's so unreliable about a turbo "kit" pulled from a DET? Just curious.
Old 11-08-2007, 11:18 AM   #15 (permalink)
nothing unrelieable from a det turbo kit.
i was just sting from him saying adding a aftermarket turbo kit. you can get into some money if you build a good turbo kit..
as far as stock turbo kits they are good, i dont know his goals or anything else either
Old 11-08-2007, 11:23 AM   #16 (permalink)
Guns kill stupid people
Feedback Score: 9 reviews
Turbo your de, you just rebuilt it, so YOU KNOW ITS GOOD. If you had not rebuilt I would say go with the det.
If you really want oil squirters pop your upper pan and head, remove rotating assembly and drill and tap. But there is no need to have oil squirters for a <400hp motor. Are they nice and do they provide peace of mind and better piston cooling, sure...
Are they necessary, no.
Have fun with your snappy throttle response on that 9.5:1 cr with a t28, it will rock at 7psi
fro20 is offline   Reply With Quote
Old 11-08-2007, 11:29 AM   #17 (permalink)
SE-R Newbie 4-life
isn't tiger selling BB for $800?
Old 11-08-2007, 11:30 AM   #18 (permalink)
McCoy's Avatar
It will rock at 11-14psi easily... I should know
Old 11-08-2007, 11:40 AM   #19 (permalink)
... like as in rice
If you buy from Tiger Japanese you will be wishing that you just went with your de. I decided to go buy a DEt with my swap and the one I bought from tiger was an absolutely horrible motor.
There were a lot of things wrong with it, but just for starters it had three coin sized pieces of metal int he turbo. I ended up losing my ass off on that motor. Then I bought one from another vendor and that DET was immaculate.
DET is great because everything is plug and play, but if you just rebuilt your DE then there is no contest on which you should use (de)
92' Nissan Sentra SE-R - bluebird SR20det woot!
PwrdByUncleBens is offline   Reply With Quote
Old 11-08-2007, 11:45 AM   #20 (permalink)
I am sure it will, just didn't know what kinda management he will use, so 7psi is safe, but 11-14 is awesome.
