Old 03-28-2008, 07:18 PM   #1 (permalink)
thewhiteone
B14 Driver
ACT Street Disc failure!
So ive been driving my boosted daily (Avenir, BC 2 cams, Fidanza and an ACT HDSS) since august for about 4-5k miles so far. So yesturday i was driving and i couldnt put it in gear. So i thought it was my cable. Replaced the cable with a new one and it didnt solve the problem so i took apart the tranny and found out the my ACT street disc's spring fell out. Now my question is why did it break so soon? Should i just replace the disc and keep the PP? Or should i try upgrading to something stronger? Ill try to post pics up ASAP. Help me! Thanks in advance.
thewhiteone is offline   Reply With Quote
Old 03-28-2008, 08:50 PM   #2 (permalink)
paNX2K&SE-R
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 65 (100%)
I had a spring pop out on my act disc but it was 5 years old at that point. Just get a new disc and you'll be fine. You might want to try contacting ACT and see if they will do anything for you since it was so new.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 03-28-2008, 09:11 PM   #3 (permalink)
VVLtrain
Mmmm gas smell..
This failure is nothing unique to your situation. A lot of SR20 clutch discs springs from different companies fail. ACT is not immune. However, I do know that ACT updated the design on their sprung hub discs. I *think* that the newer version's springs are a bit beefier, look more securely seated in the hub, and are painted yellow like their pressure plates. You might want to call ACT and find out. From what I remember, there was a noticeable difference between the older design and the updated one.
-L
VVL
'94 SE-R w/ VE
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I CAN FIX IT."
VVLtrain is offline   Reply With Quote
Old 03-28-2008, 10:05 PM   #4 (permalink)
thewhiteone
B14 Driver
alright thanks for the response. Ill try contacting them monday.
