Old 05-11-2008, 12:26 PM   #1 (permalink)
wishiwasfast
GTiR vs. Bluebird sr20det...
Im tryin to figure out which engine i should use. I know that the GTiR has higher redline, hp, and compression. but i was told that the GTiR engine will cost more to repair and its very differnet than the bluebird engine, as in vaccuum lines and such so problems will be that much harder to find. Is this true? Im swappin one or the other into my b15 before sept. i just want the better of the two engines in my car...
Thanks
wishiwasfast is offline   Reply With Quote
Old 05-11-2008, 02:36 PM   #2 (permalink)
squabzter
Trader Rating: 24 (100%)
You have not done research, its the same engine, redlines are only ecu based which if youre gonna make it go fast you would raise it anyway, and the gtir has LOWER compression, yes it will cost more.
do more research, see the SEARCH button? use it, i did, ive moved a long way
93 NX2K---Boosted!
92 NX2K---stock and staying that way--loaned
99 G20 ---Comfy for everyday cruisin
squabzter is offline   Reply With Quote
Old 05-11-2008, 03:46 PM   #3 (permalink)
wishiwasfast
lol, i meant lower compression. ok, well it was a simple question.
Old 05-11-2008, 04:02 PM   #4 (permalink)
zer099
Red Emblem
It's a largely opinionated question. I would say go with the R, but I have one. I've never had problems finding parts for my engine. And I have sourced pretty much all the options to get parts if need be.
Case in point = cams. Everyone in the States seems to assume that only JW makes cams for the R, but that is far from ture. A ton of people do (HKS, Tomei, JUN, Piper, and more) you just have to look. Most are not going to be in the States. Why would they be, the engine was never made over here.
That being said, if you are smart and look you will easily find parts if need be. Network and get in the with R groups across the world. The engine has many advantages over the others, but you do have to work to maintain it.
If you are looking for ease and quickness then go with a BB. Most replacement parts can be taken from the other SR20s and the swap should be easier. 'Course, that said you are swapping into a B15, and I would imagine both swaps would be about the same in difficulty.
So, to sum up:
GTi-R is better, stronger, has more power, and has the cool factor of being rarer, but you have to work to be able to maintain it.
BB is easier to work with, easier to maintain, but everyone and their mom has one it seems.
Oh, and also, I've never had problems with my vacuum lines. There are a lot of them, but it's not as horrable as everone is making it out to sound.
-98' 200sx GTi-R, FMIC, 3" downpipe/cat/piping/ and muffler, and some other bells and whistles
-96' B14 left stock for the daily drive... also expired
-95' S14 soon to be RB26ed once I get off my ass
-91' S13 w/ SR20DET black top... expired
-89' B12 SE... expired
zer099 is offline   Reply With Quote
Old 05-11-2008, 04:10 PM   #5 (permalink)
wishiwasfast
Ok, well as for the swap, if i get the front clip all i need are the b15 se motor mounts and it drops in. As for the parts i can get them pretty easily. i just don't want an engine thats going to have more down time than running time. Also, at first the engine is going to be completely stock for at least 6 months, and be dd for that time.
Old 05-11-2008, 08:30 PM   #6 (permalink)
kevwal
SR20 Turbo Inside
kevwal's Avatar
So, to sum up:
I have the same motor and agree with this 100%. They are both good motors, I have done plenty swaps with both. I am happy with my motor and have surprised alot of people with it.
kevwal is offline   Reply With Quote
Old 05-11-2008, 08:43 PM   #7 (permalink)
siberian21
Rockin that G20 w the DET
but you still havent learned to not be an a$$hole. Some people do search but dont know how to use the correct "key" words and they dont find what they're looking for. People get flamed on here so much its not even cool. G20.net is a great place for non-a$$es to go because most people will give criticism but its constructive. We are the same community but sometimes I feel that G owners like people more and are more willing to help. I feel that if you want to tell someone to search then just dont reply.
Sorry for the rant.
As for the question. If you want raw horsepower, the GTI-R motor is the way to go but if you have a set amount to spend and play with then the Bluebird (U12 & U13) or Aveniar (W10 & W11 SR20's) motors are cheaper and still pack a punch.
siberian21 is online now   Reply With Quote
Old 05-11-2008, 11:34 PM   #8 (permalink)
wishiwasfast
well i was planning to spend anywhere from 2.5k to 3k to complete the swap with a 5-spd conversion. i work at a nissan dealership, so i have access to a lift and all the airtools i need. i was planning to buy the whole front clip so i would have everything, and get the mounts, petals, and trans stuff oem. when i swap it im leaving it stock, no fmic, etc. For at least 5 months. from what i read it shouldnt be that hard to do. any more pointers lmk.
Thanks
Old 05-11-2008, 11:48 PM   #9 (permalink)
zer099
Red Emblem
What you have planed for the ECU? Retuning a B15 one, or rewiring the whole harness for the older engine and ECU to work in your B15?
With that price range if you are just going for a straight drop and nothing special added then go with the R. You can easily land in that range with an R swap.
Old 05-11-2008, 11:57 PM   #10 (permalink)
james23nyc
G20 DET
Sorry for the rant.
I agree with that, we arent that bad on G20.net, it's all family
'96 G20-SR20DET/5spd swap/K-Sport Coilovers/Custom FSTB/Octotat RSTB/Walbro 255lph/N60 MAF/Calum Ecu/AFPR/Skunk2 3in muffler/3in catless exhaust/Autometer Boost Gauge
james23nyc is offline   Reply With Quote
Old 05-12-2008, 07:32 AM   #11 (permalink)
wishiwasfast
[quote=zer099;2282275]What you have planed for the ECU? Retuning a B15 one, or rewiring the whole harness for the older engine and ECU to work in your B15?
QUOTE]
i was going to use the gtir ecu. and gauge cluster so there would only be the vss would have to be wired. Also, use the full harness from the clip too.
Old 05-12-2008, 12:09 PM   #12 (permalink)
zer099
Red Emblem
Cool cool, just making sure you had a plan. Good luck with the build and keep us updated.
Old 05-14-2008, 05:07 AM   #13 (permalink)
Coheed
Technician and Enthusiast
BB for me. tons of sr parts for it are readily available at your dealer. And local places carry more parts for it. It is simple and reliable. The gtir is a great motor, but because of parts availability i wouldnt take it over the bb motors.
Coheed is offline   Reply With Quote
Old 05-14-2008, 08:48 AM   #14 (permalink)
scrildo
Ruby Red SE-R
Are u kidding me?!? People still use those pre-historic bluebird motors?!?!? Avenir SR20DET FTW!!!!!!!!
Once you go turbo you'll never go back!!!
1993 Ruby Red SE-R SR20DE+T RIP junked 3/06
1995 Infiniti G20
1994 Aztec Red SE-R W10DET powered
Originally Posted by capecodbuysell View Post
whats a 2 step and how does it build boost at the line
Originally Posted by GateCrasher_VI View Post
anyone have a spare muffler bearing or two? 'reason to suspect thats where my coffee can sound is coming from
scrildo is offline   Reply With Quote
Old 05-14-2008, 12:28 PM   #15 (permalink)
Coheed
yes Avenir is the best W11 FTW! But the debate is BB vs GTiR
Old 05-14-2008, 01:13 PM   #16 (permalink)
boostenb13
Baby Godzilla
Go GTI-R 54C, Its built to take loads of boost from factory... Im very happy with mine, so is most people I know with it.
THE AIF LINEUP
*91' Nissan Sentra SE-R Classic- SR20DET 54CPulsar
*For Sale: http://www.sr20forum.com/florida/227...-r-coming.html
*93' Toyota Soarer GT-TT- Sold
*96' Nissan 200sx SE-R- Sold
*95' Silvia S14 Turbo- Sold
*85' Corolla GT-S- Sold
*94' Sentra E -Sold
*91' Sentra SE-R totaled\parted
*93' Acura GS-Sold
"Dont watch me watch ya self"
boostenb13 is offline   Reply With Quote
Old 05-14-2008, 02:09 PM   #17 (permalink)
wishiwasfast
where did you get it?
how much, how long, and what does it come with?
Old 05-14-2008, 02:34 PM   #18 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 40 (100%)
Avenir is pimp! Got a couple and have had a couple BB motors and boosted some regular DE's. They all work great.
Brent
