Old 05-13-2008, 01:48 PM   #1 (permalink)
tomas325i
MAF and TPS for my Sentra
Im new to NISSAN,
I got a 2000 Sentra SE Turbo. It has the reprogramed JWT b14 ECU, it's prgramed for Cobra MAF sensor, I need a new one ,where can I buy it? The car has scafII and 50lb injectors. I also need a new Throttle position sensor, I took the old one of it's the one with two connectors, but when I searched online by the part number on it, I didn't find any same one, I found ones that look alike but part number is different. What do you guys have for TPS on your cars? Should I just get one from a b14 sentra?
I would be very thankful if you guys gave me some links where to buy these two sensors.
tomas325i is offline   Reply With Quote
Old 05-13-2008, 01:56 PM   #2 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 40 (100%)
Why did you pull them off? TPS rarely goes bad, just needs to be calibrated. The MAF, what is the issue with that? Greg Vogel can souce you the tps sensor if you really need it, gspec.com. The MAF, just shop around for best price on the cobra maf. I think JWT likes the 93 one, but it has been a while.
Brent
Old 05-13-2008, 09:39 PM   #3 (permalink)
serturbo98
i have one that i got from jwt. i am using the lightning maf now so you can call me at 615-962-3879 if you still need one.
serturbo98 is offline   Reply With Quote
Old 05-13-2008, 11:09 PM   #4 (permalink)
tomas325i
SENSORS
Well I don't know whats up, but when I plug the ecu up to my computer b/c service engine soon light is on, it showed me codes for TPS and MAF.
Old 05-14-2008, 11:31 AM   #5 (permalink)
tomas325i
At first the car was running but the idle was jumpy, after few turn off and turn ons the car wont even start but still cranks, and its shows codes for those two sensors, what can be wrong?
