Old 05-13-2008, 04:46 PM   #1 (permalink)
qctuner
Advices needed with RR to avenir swap
So i'm in it with the swap, there are some things i'm not shure about that i'd need answers.
-Power steering pump, i decided to keep the det one hith the RR hose, but there is a plug with 2 vacuum hoses pluged in... usless now?
-There are now 2 intake valves unpluggeg since i'm using the RR harness, Keep them unplugged? (one is near the BOV and the other is under Intake manifold)
-There is a valve wired with the injectors harness with 2 vacuum hoses plugged in, useless or i need to plug the vacuum hoses the same spot they were on the RR motor?
-Injectors, i have to wire inline resistors to run det injectors with RR harness, what is the value of the resistors needed ? Think i've read 6.8ohms/20watts...
is that ok??
Really need thoses advices... thanks for replying.
qctuner is offline   Reply With Quote
Old 06-09-2008, 02:50 AM   #2 (permalink)
Rojeda1217
sounds like a gtir swap more than an avenir. i thought the w10's were a plug and play swap
Rojeda1217 is offline   Reply With Quote
Old 06-09-2008, 07:31 AM   #3 (permalink)
200SXDRIVER
On an avanir swap you should end up with 2 empty harnesses. One for the egr valve, and one for the egr temp sensor. I just did the avanir swap on a '95 SER and those were the only pieces I didn't use.
200SXDRIVER is offline   Reply With Quote
