Old 06-07-2008, 05:51 PM   #1 (permalink)
injector problem?
my car has the bluebird swap will not start unless i put starting fluid in the intake then it will only rev once or twice and die gas is getting to the injectors.....dont know for sure what it is could it be the ecu or is it for sure the injectors or could it be a fuse?????any ideas would be helpfull
acurals98 is offline   Reply With Quote
Old 06-07-2008, 06:20 PM   #2 (permalink)
Weekend Warrior
Trader Rating: 33 (100%)
^What ecu are you running and what MAF?
BEND BUT DON'T BREAK
93 SE-R
Project-4Door-B13 "Building it one paycheck at a time"
FB1 - FB2 - SR20 storage building part-out LINK
MR-4Door-SR20DE is offline   Reply With Quote
Old 06-07-2008, 06:37 PM   #3 (permalink)
jwt ecu and z32 maf
Old 06-07-2008, 07:14 PM   #4 (permalink)
You have injector pulse? Just got my ecu back from JWT last month and now 2 injectors don't fire which they claim is nothing they did.
200SXDRIVER is offline   Reply With Quote
Old 06-07-2008, 08:28 PM   #5 (permalink)
51/50
are you sure that the fuel supply and return lines are hooked up correctly,it could be easy to mix up
t slim is offline   Reply With Quote
Old 06-07-2008, 08:39 PM   #6 (permalink)
well it was already runnin but one day it just stopped runnin it started but only idled and wouldnt do anything with the gas peddle then it died and stopped runnin....but before it stopped runnin every once in a while my fuel pump would kick on unless i moved it around..
Old 06-07-2008, 08:40 PM   #7 (permalink)
how would i check if i had injector pulse?
Old 06-07-2008, 09:24 PM   #8 (permalink)
work in progress...
Trader Rating: 26 (100%)
Check your fuel filter.
SR20DEEP in TX
Old 06-07-2008, 09:30 PM   #9 (permalink)
i did it seemed fine but i put a new one on anyways
Old 06-09-2008, 07:37 AM   #10 (permalink)
Buy a noid light set from advance auto for $20 and stick a noid light in the injector clip, then crank and see if it lights up. Also, make sure you are getting 12V on the white wires going to the injectors. I would check the 12V first though it's unlikely you blew both the injector drivers at the same time and had you blown only one it would still run on 2 cylinders.
