my car has the bluebird swap will not start unless i put starting fluid in the intake then it will only rev once or twice and die gas is getting to the injectors.....dont know for sure what it is could it be the ecu or is it for sure the injectors or could it be a fuse?????any ideas would be helpfull
well it was already runnin but one day it just stopped runnin it started but only idled and wouldnt do anything with the gas peddle then it died and stopped runnin....but before it stopped runnin every once in a while my fuel pump would kick on unless i moved it around..
Buy a noid light set from advance auto for $20 and stick a noid light in the injector clip, then crank and see if it lights up. Also, make sure you are getting 12V on the white wires going to the injectors. I would check the 12V first though it's unlikely you blew both the injector drivers at the same time and had you blown only one it would still run on 2 cylinders.
