Old 09-21-2008, 01:12 PM   #1 (permalink)
Does not boost more than 10PSI(Open Boost)
After getting my new fuel pump and relay installed I now have a new problem!
My boost does not go any higher than 10psi with the vacuum line removed from the boost controller.(Open boost) GTI-R swap. I had it set to 12 before and got a max of 16psi.(spike) but now it does not go any higher than 10 and it does not feel like a strong 10. builds up slow. check the actuator to see if the diaphragm is bad but everything is good.
Any suggestions??
JDM_Primera is offline   Reply With Quote
Old 09-21-2008, 01:26 PM   #2 (permalink)
SR20DEbT
Trader Rating: 53 (100%)
Boost leaks? I'd start by pressure testing the system. My wastegate line shot off and the car spiked to 25-30psi. Is the car detonating or anything when it reaches 10psi or just creeps to 10 and just sits?
-Bes
92 Sentra GTi-R
Small Snail Crew
----BNB----
Old 09-21-2008, 02:43 PM   #3 (permalink)
LikeTheMovies's Avatar
Trader Rating: 17 (100%)
my vacuum line was off and i blew my turbo
99 Sentra SE-L (Turbo)
*Avenir Motor/GT28R Turbo/3" Downpipe/Nismo AFPR/370cc/Calum ECU*
*Hypercos W/AGX's and ME Rear Mounts*
*VRS 2.5" Exhaust*
*NX2000 Brakes*
14.27@100mph 213whp 198tq. Old Setup
New Setup Coming Soon!! GT28R
95 200sx Se-R (For Sale)
15.061@91mph
LikeTheMovies is offline   Reply With Quote
Old 09-21-2008, 02:53 PM   #4 (permalink)
I haven't pressure tested the system but it ran fine before the fueling issue.
it does not creep to 10 but goes up as normal and stays there at 10
Old 09-21-2008, 11:02 PM   #5 (permalink)
Monkey Power
pressure test the system first. If you do not have any leaks run the car with no line on the waste gate. Be careful not to over boost or you will detonate. If the boost presssure does not rise with the line off you may have a crack in the exhaust housing around the waste gate port. this is a very common problem.
94 se-r 342whp 289lbft @ 15psi
92 se-r sr20ve with N1 cams
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
cortrim1 is offline   Reply With Quote
Old 09-22-2008, 10:38 AM   #6 (permalink)
Could not get the car tested, cant find someone with the equipment. But I did remove the VAC line from the actuator and it when straight up to 15 and then I stopped revving. I put back the stock tee piece that leeds to the stock boost controller(but not connected) and it could not get past 10 again, so I removed the tee piece and ran the lines straight to the turbo smart boost controller and it operates fine. and now the vac is reading a lot more stable at 16-18. Cant wait to take her out for a test drive. (not with 15psi though).
so hopefully that takes the cracked manifold out.
What do I need to pressure test the vacuum?
Old 09-22-2008, 11:28 AM   #7 (permalink)
Kicking it over @ g20.net
theres a DIYsomwhere onhow to make a pipe pressure tester from stuff from homedepot.....ill try to find it
enohand is offline   Reply With Quote
Old 09-22-2008, 11:35 AM   #8 (permalink)
just wait...
here ya go..
http://www.sr20forum.com/turbo-guide...re-tester.html
anthony
antser is offline   Reply With Quote
Old 09-22-2008, 03:51 PM   #9 (permalink)
thanks!! will try this out
