returning turbo drain line into the sump - SR20 Forum
Old 10-19-2008, 07:41 AM   #1 (permalink)
is this possible? i do not want to drill the block as i am unable to drop the engine and dont have the tools.
Cheers
mitsi factory turbo charged engines return their turbo return lines to the sump.
clip14 is offline   Reply With Quote
Old 10-19-2008, 07:47 AM   #2 (permalink)
Enemy of the stupid
Feedback Score: 9 reviews
As far as I know thats the only way to get the oil back into the motor. If you put it into the 2nd oil pan the oil will back up and you won't have the oil draining out of the turbo. The Engine does not need to come out to be tapped for the oil drain.
91 NX2000 VE forsale
Protech-Fabrication
http://www.OSRdyno.com/
Old 10-19-2008, 09:30 AM   #3 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
VW also returns the oil to the pan in the 2.0t and I think the 1.8t. However the sr20 pan is very shallow, so there's not much room to place a return fitting, and your oil return line is going to be hanging pretty damn low.
That said - the only special tools you need to do it the 'right' way on an sr20 are a drill and tap. And the engine doesn't have to be dropped. Basically you remove the header, radiator, fans, crossmember, lower & upper pans, and then you're ready to drill.
Old 10-19-2008, 11:52 AM   #4 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
do it right or you'll regret it later.
92 NX2000 2860RS
Old 10-19-2008, 12:35 PM   #5 (permalink)
sleeper
The oil drain should return the oil above the oil level in the oil pan. The Evo has a very deep oil pan, the SR20 does not. Hence, why the SR20 returns the oil to where it does.
You do NOT need to drop the motor. I don't know where you got that idea. At the MOST, you have to take out the radiator. Do it the right way the first time!
Khiem
'05 Evo
'05 CBR 600RR
Old 10-20-2008, 04:35 PM   #6 (permalink)
This sr20 will be installed longitudinally in a silvia so gaining access to the oil return is a lot more difficult because of the lack of space. the motor has to be dropped to allow access and to also allow a perpendicular hole to be drilled and tapped.
Old 10-20-2008, 05:19 PM   #7 (permalink)
i believe for the RWD SR20 there is an aftermarket oil pan that has a tap/threaded hole built-in.
Old 10-20-2008, 05:29 PM   #8 (permalink)
do you have any links to this aftermarket oil pan?
Old 10-20-2008, 05:32 PM   #9 (permalink)
try greddy, moroso, and arc oil pans.
Old 10-20-2008, 08:10 PM   #10 (permalink)
Ruby Red SE-R
Feedback Score: 4 reviews
I dont know if this helps any but depending on what type of manifold and turbo you are usuing u can put the oil drain(return) directly to the part that the OEM oil catch can or oil seperator whatever its called drains into you know The black can thing on the front or the motor. When i had the turbo setup on my marron B13 SE-R I had a log manifold with a 20G and thats where I drained and the car was fine for the 2 years or so that I had it boosted.
Once you go turbo you'll never go back!!!
1993 Ruby Red SE-R SR20DE+T RIP junked 3/06
1995 Infiniti G20
1994 Aztec Red SE-R W10DET powered
Originally Posted by capecodbuysell View Post
whats a 2 step and how does it build boost at the line
Originally Posted by GateCrasher_VI View Post
anyone have a spare muffler bearing or two? 'reason to suspect thats where my coffee can sound is coming from
scrildo is offline   Reply With Quote
Old 10-20-2008, 08:50 PM   #11 (permalink)
sleeper
Hmm..... well, one option is to go with a spacer that pushes down the oil pan an inch or so, and provides and oil drain spot. Look at the spacer for the 350Z turbo kit from JWT.
Old 10-20-2008, 09:21 PM   #12 (permalink)
youd also have to get a spacer for the oil pickup
Old 10-20-2008, 09:52 PM   #13 (permalink)
from FrontWD to RightWD
Feedback Score: 6 reviews
i tapped the upper oil pan. ill get pics. its working fine. i did it there because if i f*ed the block i would have killed myself. if i f*ed up the upper oil pan i had another.
Old 05-06-2010, 10:59 PM   #14 (permalink)
Pics please! I'm considering tapping the upper oil pan instead because it could be done outside of the car on a spare oil pan I had. I don't see how it would be that big of an issue because it's only 1.5" lower than the location on the block where everyone else taps.
fullahwickednez is offline   Reply With Quote
