Old 07-02-2009, 01:00 AM   #1 (permalink)
Civic beater
turbo lag
I've heard from my pops he's a pro dragracer that if you have a higher compression motor you have less turbo lag on your car, I know it'll give you more horspwer but idk about less turbo lag... Is it true? if anybody knows let me know cause ive searched and i can't find if its true or not...
B13 white SE-R (parting out)
B13 red XE-R turbo BABY!!! vroom vroom
sr20_B13 is offline   Reply With Quote
Old 07-02-2009, 01:04 AM   #2 (permalink)
banned
yes its true.
sergod is offline   Reply With Quote
Old 07-02-2009, 01:36 AM   #3 (permalink)
from FrontWD to RightWD
true to a certain extent.
i dont think it really makes a difference that you can feel.
it has more to do with the turbo, piping, intercooler, restrictions (TB) and your bov
Old 07-02-2009, 11:48 AM   #4 (permalink)
Civic beater
How does it give it less turbo lag
Old 07-02-2009, 03:04 PM   #5 (permalink)
Ya momma!
Trader Rating: 31 (100%)
small intercooler piping will give you less lag too.
High compression is just less boost to make same numbers that low compression makes at higher boost. Make sense?
1997 200SX SE-R - 246whp & 230tq
"Shut the fu*k up and sit down"
Old 07-02-2009, 06:24 PM   #6 (permalink)
IMO less boost = more usable power
Old 07-02-2009, 06:38 PM   #7 (permalink)
Allot of factory turbo cars come with between 9.5:1 and 10:1 compression now.
With higher compression comes better response and better torque figures however it requires better tuning, as the margin for error is less. That said I believe the perfect compression for a boosted sr20 is 9.5:1
jmdsentra is offline   Reply With Quote
Old 07-02-2009, 08:41 PM   #8 (permalink)
Trader Rating: 15 (100%)
9.0:1 is ideal IMO
morgans432 is offline   Reply With Quote
Old 07-02-2009, 10:56 PM   #9 (permalink)
Civic beater
What does IMO stand for... I have stock internals on my highport how many lbs of boost should you guys recommend? and what size of IC piping should you guys recommend also?
Old 07-02-2009, 11:04 PM   #10 (permalink)
merely a flesh wound
chriscar's Avatar
Trader Rating: 109 (100%)
What turbo, injectors, maf and exhaust are you running?
1994 SE-R / SR20VE / N1 Cams / B15 trans / Calum Realtime / Hyperco - AGX / 15x7 RPF-1
1995 Turbo Miata R Package / GT2560R turbo / Megasquirt / Tein Flex / 15x8 949 6UL
Old 07-02-2009, 11:16 PM   #11 (permalink)
Civic beater
I have 370cc, the garret T25, Cobra MAF, and a 2.5" exhaust to a cherrybomb and to my stock axle back muffler
Old 07-03-2009, 02:52 AM   #12 (permalink)
i had 2.25" hot side and 2.25-3" cold side piping on a t25 setup with a 10:1 motor. lol no boost lag at all. i made full boost around 2200rpm lol
tear that stock axel back off!!
IMO= in my opinion
Old 07-03-2009, 06:31 AM   #13 (permalink)
Civic beater
thanks bro for the info and IMO was confusing the hell out of me
Old 07-03-2009, 08:26 AM   #14 (permalink)
chriscar's Avatar
The lag issue you were worrying about does not exist with a T25, it's got instaboost.
I wouldn't run more than 14psi on that T25. Beyond that it's out of its' efficiency zone and is pretty much just blowing hot air. The limiting factor in your setup is the injectors. Since you don't have an ECU yet, get one programmed for 370cc, 4 bar fuel pressure.
For your IC pipes, go 2" on both sides, or 2" hot, 2.5" cold because one of these days you'll probably want a bigger turbo. And get yourself a 3"exhaust.
Old 07-03-2009, 02:02 PM   #15 (permalink)
Civic beater
oh yeah i forgot i do have have a tuned ECU forgot to metion that
Old 07-03-2009, 02:15 PM   #16 (permalink)
chriscar's Avatar
If you're running 3bar, then limit yourself to 12psi to be safe. You really should get some way to monitor your injector duty cycle. Unless you have a Calum realtime, the easiest way to do it is with a Consult cable like this.
http://www.blazt.biz/products/cable.php
http://www.sr20forum.com/technical-i...hp-output.html
Old 07-03-2009, 02:34 PM   #17 (permalink)
Civic beater
all i have to do is just buy the cable and software and i plugs in to my OBD input to my laptop? is that correct? I appreciated so much for your help... ALOT...
Old 07-03-2009, 02:43 PM   #18 (permalink)
chriscar's Avatar
Yep, that's it. Calumsult is free, and there's a free version of ConZult, but I'd recommend you purchase the software with the cable.
Old 07-03-2009, 02:55 PM   #19 (permalink)
Civic beater
wich one shoud i but though theres alot of different ones
Old 07-03-2009, 03:03 PM   #20 (permalink)
chriscar's Avatar
Here's another option - http://www.ecutalk.com/interface.aspx
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
