not direct drop in. need to splice connectors off of harness and tune ecu, latency, ttp min, max etc. Check with the guys on the subaru forums and they'll help you out with latency and all.
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 520cc injectors, .3 bar fuel pressure, n62 maf, log manifold, Tial 38mm wastegate (9lb spring), 3" downpipe-3" VRS Exhaust, PLX Wideband, Calum basic ecu.
Balls to the wall until you see God, wait three seconds then hit the brakes...
