Hey guys,
Well since I went turbo Ive had a ton of little Gotchas, I wouldn't say major problems at all just little issues 1 by 1 im overcoming..
Basic Info before I go off on tangent.
- Avenir DET ( 9lbs stock boost )
- N62 MAF in Billet MAF box ( blow thru ) 12" from TB
- Greddy Type S ( venting to atmosphere ) 6" from MAF
- CALUM Basic
- 370s @ 3 bar
- Stock Fuel Pump ( walbro 255 is enroute )
OK so I get the car up and running and theres a high idle, 1500-1800 RPM and once it warms up it was fluctuating ( 1000 / 1800 or so )
back and fourth but never once wanted to die.. Led me to think IACV vacuum was always 20hg or so.
When going full throttle the wideband would read 12-12.5 perfect.. Besides the wierd idle car would start right up, Blows no smoke ran great.
Just had the wacky idle.
Fast fwd 100 miles or so and I noticed the wideband on full throttle would be 12.5 / 13.0ish and then i stopped getting on it hard but once in a while i would monitor
and lay into the throttle and see 13-14 almost no 12s. Mind you these were super short pulls. After that I figured this pump seems to be getting a little weak Ill just baby it around.
Went to drive home from work and at light throttle it would drive then just started to buck like it had no power you could put your foot to the floor and just nada wouldn't rev..
Put in neutral REV it and it would feel fine without load. When the bucking would occur the gauge would go really rich sometimes but idle would be lean.
Then I came to a red light and it would stall out repeatedly.. Wideband would read rich when this was happening sometimes and at idle it would be pegged lean.
Went back to work for 4 hours and when I left still had my idle issue but car drove fine. * sweet made it home *
So now that the troubleshooting has begun I have no clue what it is. I have no codes occasionally ill get a maf code but I believe that maybe from the VENTED BOV.
If I go and cold start it , it idles high but steady at 1800 but doesnt try to stall, Once it gets warm wants to stall right out and you cannot drive it, it will hover at 700rpm/1000rpm
If you rev it in neutral parked it pretty much revs fine and smooth, but you could try a second time and it wont even wanna rev and just falls on its face.
Check out these videos - not the best but if you double click they will go full-screen CLEAR they are 720P HD Should help.. Dying to drive this car!!!
Data log video ( Nissan Data Scan & Wideband while trying to idle )
http://www.youtube.com/embed/YzwJbnROLqY?hd=1
Fuel Pressure Gauge Vid ( not sure what is normal ) Stock Pump. CANT FIGURE OUT how to embed on here
http://www.youtube.com/embed/2GEFLLV0gpg?hd=1
Any help would be appreciated I think maybe part could be a fuel pump but then again im not 100% on that ( ordered walbro 255 regardless ) Just wanna enjoy this car in the perfect weather.
