RWD NA SR20DE-T BUILD - SR20 Forum
Old 11-22-2011, 11:41 AM   #1 (permalink)
first off
i *** many ppl prefer the sr20det to its NA counter part
since owning 240sx for the last 10 yrs Ive been on both sides
and its an awesome car...period....
ka24de vs sr20det....
ka has displacement and good torque ..2.4L...
broke many ka due to heavy foot syndrome
Sr factory boosted 2.0L.......can rev higher...
great daily driven turbo engine....
Sr20det..vs NA sr20de rwd
factory boosted...2.0L
8:5:1 comp
oil squirters.
sodium filled valves
predrilled block for turbo application
NA sr
10:1 comp
high reving like its det counterpart
ive owned A SR20DET in an 89 coupe for like 5-6 yrs so
done many swaps....
turbo upgrades...
harnesses...
wiring upgrades..
i decided to take this journey
since i so happened upon a fresh auto sr20de na
it came running in a s13 hatch i bought
Drove it to my shop and started the deconstruction- reconstruction
NOW
then there's two ways to go about the turbo setup
oem sr20det turbo setup...water and oil
or a t3....oil only
i am opting for the det oem setup since for me its cheaper
BUT T3 SETUP ONLY NEEDS OIL FEED AND RETURN
having all the parts would help
i purchased the lines from ebay lol..
cheap but ive have them on my det so they werk for me
KA SS OIL FEEDLINE FOR T25 TURBO...20
SR20DET SS OIL LINES FOR BB....55
REBUILT T25....95...
OEM DET MANIFOLD...FREE
EBAY OVERSIZED OIL PAN...40
OEM SR20DET RWD OIL DRAIN FITTING FROM BLOCK....20..OR FREE
SR20DET WATER HEATER TUBING/PASSAGES...FROM UNDER INTAKE...20...OR FREE
FRESH METAL GASKETS AND LOCKING TABS FOR TURBO, MANI..ETC..20...
EBAY FMIC KIT W BOV...USED...150...
MSD BLASTER...HAD IT....
370CC SR20DET INJECTORS....NEEDED
WALBORO 255 F/P...NEEDED
SAFC2...NEEDED
THE SECRET TO RUNNING A SR FROM A KA HARNESS
I INSTALLED A NEW HEAD GASKET JUST TO BE SURE
DONE W HEAD GASKET...
INSTALL HEATER TUBE WITH WATER OUTPUT LINE AND INTAKE
REMOVED WATER INLET PLUG AND INSTALLED FITTING
INTALLED TURBO TO MANI WITH NEW METAL GASKETS NUTS AND LOCKING PLATES...
OIL OUTPUT FROM BLOCK
OIL RETURN
MY COUPE
WAITING ON THE LAST PARTS BEFORE FINAL RECONSTRUCTION
TO BE CONTINUED
driftapimp is offline   Reply With Quote
Old 11-22-2011, 02:00 PM   #2 (permalink)
S12 NUT
Looks like a good start.
Though the S13 SR20DE is 9.5:1, not 10:1. The S14 and S15 is 10:1.
I would recommend that you drill and tap the block for the OEM oil return, having it in the lower oil pan like that is opening you up for a huge oil leak and oil return issues (the oil level can come up past the top of the hose fitting).
And it's not hard to do, especially since you already have the engine out. Though the tap is a little expensive, depending on where you get it from ($20).
1987 Nissan 200SX/Silvia (S12) Specs:
  • SR20DE+T (94 S14, VCT)
  • 9.5:1 Compression (Sentra pistons)
  • T25 @ 11PSI
  • 450CC DeatschWerks Injectors @ 60PSI (528CC/min)
  • Bosch 023 Fuel Pump
  • MegaSquirt Extra 029y4
  • Custom FMIC
  • Currently maxing out injectors!
seishuku is offline   Reply With Quote
Old 11-27-2011, 05:19 PM   #3 (permalink)
NXR Turbo User
^^ I agree.
Seeing as how you changed the sump, anyway, you could have cleaned the block out, easily enough.
Built not Bought!!
SR20pulsar is offline   Reply With Quote
Old 11-27-2011, 11:40 PM   #4 (permalink)
Enemy of the stupid
Feedback Score: 9 reviews
That oil drain is way too low like seishuku said. Oil won't drain out if it's sitting in oil. Remap the stock KA ecu with a realtime board and it should live for a long time if tuned right.
91 NX2000 VE forsale
Protech-Fabrication
http://www.OSRdyno.com/
Old 11-28-2011, 05:08 PM   #5 (permalink)
yeah well im ***** see *** happens
with the return being there
Old 11-28-2011, 08:14 PM   #6 (permalink)
Enemy of the stupid
better get a santa fe sticker for the car because your going to be smoking like a locomotive. Don't be lazy just do it right the 1st time.
Old 01-05-2012, 02:43 AM   #7 (permalink)
Man im doing the same thing. Got a na s15 sr20de and put all my 13 de-t sh*t on it.
I have a freddy pan and thought about tapping exactly where you did but quickly threw out the idea and tapped the de-t location.
The story was too good to be true. Anyways. I had bought a sr with a spun bearing, yadda yadda. Ended up needing close to a grand in machine work. fu*k that, the NA sr became avaliable for 150$. I bought it, put all my sh*t on it. sh*t has great midrange. Started making a knocking sound, think its a wrist pin.
r3d240sx is offline   Reply With Quote
Old 01-19-2012, 12:45 AM   #8 (permalink)
NICE MAN
YEAH I HAD THIS SR RUNNING BEFORE AND IT WAS SWEET
I HAD TIME SO I PULLED IT DID HEAD GASKET
AND DO A ONCE OVER BEFORE I BOOST IT
Old 01-19-2012, 01:02 AM   #9 (permalink)
Enemy of the stupid
