Pressure test for intercooler pipes
Alright quick story
Last year put in det motor stock cams and pressure test worked good
Put in s4 cams and ran good.
Now took motor out to replace throw out bearing. And now I did pressure test with s4 cams installed and I'm getting no pressure. Would pressurizing the pipes and motor not hold pressure *** of the cams? Does it need to be at a certain posistion now? When in boost on the road it's seems fine but just wanna know if the cams would be making me not hold pressure.
My idle on start up is high 1500-1900 and will stay that way even for a long time then if I come to a stop the idle jumps from 1000-2000 back and forth it won't idle fine unless I go on a drive for a lil bit.
i was thinking a leak but Why would it idle ok later?
Any input would help Thanks
