Hes got spark, hes got fuel, it won't start up even on starting fluid, I came over his house one time ( kinda bad time too right after a party) and I glanced at the motor, every connector is plugged in, it keeps on flooding out the spark plugs. TPS is set to .5V I belive- ECU needs to see 4V in order to go into CLEAR FLOOD MODE- where it will fire the plugs but won't fire the injectors. This is done only when someone floods the combustion chambers with too much gas and car don't wanna start. In order to initiate clear flood mode U need to floor the accelerator pedal and then crank the engine over. I need to look at the car again sober sometime soon.
Mike Jez- Acura/Nissan Master Tech- as a daily job.
2004 Volkswagen R32 - best car ever owned.
2002 Honda RVT1000R - track beast #2.
