Spark plug gap + horsepower gain + better gas milage - SR20 Forum
post #1 of 61 (permalink) Old 05-02-2004, 05:56 PM Thread Starter
banned
Quoted: 0 Post(s)
Feedback Score: 5 reviews
(Thread Starter)
I have been using NGK BKR7E-11 gapped at .025 for quite sometime, I recently started experimenting with a larger gap, I am running a .040 gap now with the same plugs and the engine runs much much smoother and revs alot faster especially in the upper rpm's and the cars seems to come on to boost a tad bit quicker............I think next i'll try what the DET really calls which are platinums when I save some money and run the .044 gap. And my gas milage has gotten better since upping the gap to .040..........I went from 8.8 gallons given me 170 to 180mpg to today a best of 210mpg with 8.8 gallons. Anyone here every try this?
charlie2020 is offline
post #2 of 61 (permalink) Old 05-02-2004, 06:12 PM
70/30 Racing
Rockwood's Avatar
Quoted: 2 Post(s)
Re: Spark plug gap + horsepower gain + better gas milage
no, i will have to see how they will do at 0.040" at 20+psi and C16....
I'm too old for this shit...
Rockwood is offline
post #3 of 61 (permalink) Old 05-02-2004, 06:30 PM
Gone V8 Hunting Lately?
Quoted: 0 Post(s)
Feedback Score: 3 reviews
I was running the BKR7E's at .038" gap and all was fine until 17psi. I had to close then down to .035". I am running a MSD Digital 6 with a Blaster SS coil, but it has to cut through water molecules from my Aquamist water injection. Without the water turned on I am sure I would be able to run ~.040" gap at 17psi+.
1997 Nissan 200SX SE-R
1F@$t9d7 is offline
post #4 of 61 (permalink) Old 05-02-2004, 06:43 PM
70/30 Racing
Rockwood's Avatar
Quoted: 2 Post(s)
well, we shall have to see how it does on mine, i dont have water injection.
Rockwood is offline
post #5 of 61 (permalink) Old 05-02-2004, 06:50 PM Thread Starter
banned
Quoted: 0 Post(s)
(Thread Starter)
Don't forget I only got a T25 at 9psi to, I am sure there is a point where .040 becomes to big but I also know alot of peeps with T25 running these super small gaps, I know personally I wouldn't run any smaller than .040 probably even .044 (just haven't tried that gap yet) with a T25 with or with out cams.
post #6 of 61 (permalink) Old 05-02-2004, 06:54 PM
Old School
Quoted: 0 Post(s)
I'm running BKR6Es at .025 and my highway mileage is consistently around 30mpg.
Lew
lshadoff is offline
post #7 of 61 (permalink) Old 05-02-2004, 07:06 PM Thread Starter
banned
Quoted: 0 Post(s)
(Thread Starter)
I could use 30mpg with these damm gas prices, im getting there im up from 18-19 to around 23-24mpg now, I also replaced a cracked ingition coil and a bad MAF. I think my ECU is still adjusting fuel trim as my milage is getting better with each 8.8 gallons added.
post #8 of 61 (permalink) Old 05-02-2004, 07:12 PM
WWJD
Quoted: 0 Post(s)
Feedback Score: 7 reviews
How much are those plugs,I need some new ones
91 Gxe auto(SOLD)
91 Turbo SER(CRASHED)
91 Turbo SER(SOLD)
01 Acura CL Type-S(TRADED IN)
04 Acura TSX(stolen)
06 GSXR 600(crashed via little brother)
92 VE Powered NX2000(SOLD)
99 G20T 5 SPEED (SOLD)
92 GAY16 B13(FORSALE)
06 M35 5SPD AT NAVI REAR VEIW CAM(DAILY)
TREYDEE is offline
post #9 of 61 (permalink) Old 05-02-2004, 08:28 PM
SR20 Enthusiast
Quoted: 0 Post(s)
I ran .35 at 15psi on the t25 and it loved it. I notice alot of people run such tight gaps. I run it as loose as possible right before it starts to break up. I was running .40 but it would break up depending on the weather.
2004 GMC XUV Cranberry Red Metallic
2006 Cadillac SRX Phantom Grey
2004 GTO Torrid Red/Black M6
447.08whp/393.80wtq
12.69@117.83mph
Stage III LS6 Heads|234/228 .576/.571 113LSA Cam|SW LT's|ORP's|Corsa|ASP Pulley|FAST 90/90|40lb. Inj.|CS Maf tube|MPD CAI box|3.91's|Spec 3+|BMR Driveline|BMR skid plate|Harrop Cover|SLP Swaybar/endlinks/linelock
Awaiting install: Project Natural:gr_devil:
dougnosser is offline
post #10 of 61 (permalink) Old 05-02-2004, 08:34 PM
70/30 Racing
Rockwood's Avatar
Quoted: 2 Post(s)
another thing of import:
i talked to mike kojima and jim wolfe a couple of months back, and they were saying that the platinum tipped plugs work a lot better. platinum may not conduct better, but under the nasty conditions of your combustion chamber, they last a lot longer. if you have a plug that is getting burned away, this is a great spot to start a hot spot, which leads to detonation.
so, point in case: run platinum, its mo bettah.
Rockwood is offline
post #11 of 61 (permalink) Old 05-02-2004, 08:43 PM
Old School
Quoted: 0 Post(s)
BKR6E are $1.66 ea. from Courtesy. They don't last like plats, but at that price you can change them pretty often.
Lew
lshadoff is offline
post #12 of 61 (permalink) Old 05-02-2004, 11:22 PM
Devil's Advocate
Quoted: 0 Post(s)
Been running .35 for a long time now. Always read about don't go anymore than .28 or .30, you will detonate. Anyways, guess alot of people are starting to realize somethings aren't always true.
04 G35s Sport/6MT/NISMO Aero/Z-Tube/K&N Filter/Plenum Spacer/NISMO susp/TR MT-1 wheels/Brembo's/Clear Corners/Stillen Sways
02 Vibrant Blue SpecV/NISMO CAI/ES MMI
92 Classic/U12/GT2860RS/Divorced o2/CXR FMIC/Calum R/T ECU/Zt-2/Z32 MAF/S15 inj/Apexi TT/Greddy Profec B/3" Turbo Back/Hyperco Gen II's/KYB AGX's/ES Mounts/Cluthnet Type 1 P/P-6 Puck Disc/Jun Flywheel/NX2K Brakes/Silver Kosei K-1's
Hybrid_DET is offline
post #13 of 61 (permalink) Old 05-03-2004, 02:44 AM
now on the West side!
NismoSER's Avatar
Quoted: 0 Post(s)
Feedback Score: 17 reviews
I've been running .028 on BKR7E's for about a month now, consistently getting 24-25mpg on 11psi on 93 or 94 octane. I'll try the .040 and see what happens.
Chris
'91 VVL-powered SE-R SOLD
'04 G35 6MT
NismoSER is offline
post #14 of 61 (permalink) Old 05-03-2004, 08:52 AM
Learn to swim
Quoted: 0 Post(s)
I am running 42 gap on platinum 7e's, with no running problems. I have had them as high as .45, but I have also replaced the cap, rotor, plugs, and coil recently...Josh
"A lot of Christians wear crosses around their necks. Do you really think that when Jesus comes back he will want to see a fucking cross? It's kind of like walking up to Jackie Onassis wearing a rifle pendant."
-Bill Hicks
UNDRCOVR is offline
post #15 of 61 (permalink) Old 05-03-2004, 10:26 AM
sleeper
Quoted: 0 Post(s)
You won't get detonation, just misfire at high boost levels if the plug gap is too big.
Khiem
'05 Evo
'05 CBR 600RR
spdracerUT is offline
post #16 of 61 (permalink) Old 05-03-2004, 11:03 AM
GT30R'd Up
Quoted: 0 Post(s)
I'm running 7E's at .35 I've got to try .40 if you say your Mileage has gotten better....
Allan
96 SE-R GT30R'd Up
07 G35S Sedan
Nizmonik SE-R is offline
post #17 of 61 (permalink) Old 05-03-2004, 03:34 PM
70/30 Racing
Rockwood's Avatar
Quoted: 2 Post(s)
Lew
yeah, but you have to make sure to check the electrode often, as the copper ones dont last as long. if youre really pushing it, is it worth a motor over $4 a spark plug?
Rockwood is offline
post #18 of 61 (permalink) Old 05-03-2004, 03:59 PM
Godzilla
Quoted: 0 Post(s)
THATS SO TRUE.
IN BOOST WE TRUST.
Specialist-V is offline
post #19 of 61 (permalink) Old 05-03-2004, 06:35 PM
Old School
Quoted: 0 Post(s)
A worn spark plug won't hurt the engine. It will just develop a miss at high boost.
Now if they exploded when they were worn out, that would be different.
Lew
lshadoff is offline
post #20 of 61 (permalink) Old 05-03-2004, 06:46 PM
70/30 Racing
Rockwood's Avatar
Quoted: 2 Post(s)
Lew
a worn spark plug is a good place for premature combustion to start. worn plugs form hot spots, which may lead to detonation. trust me, i used to be a huge advocate of "copper" plugs.
this is according to Jim and Clark, people who know more about engine management than 10 sr20forums combined.
Rockwood is offline
  SR20 Forum > Main Forums > Turbo
User Tag List
