Old 09-26-2007, 12:54 PM   #221 (permalink)
El Verdugo
Originally Posted by MR-4Door-SR20DE View Post
^THAT IS VERY IMPRESSIVE..........STILL HASN'T BROKE YET?
Very nice power on this car. Congrats.
EFI-101 7-16
AEM EMS Factory Trained
Corr Performance Tuning
El Verdugo is offline   Reply With Quote
Old 10-13-2007, 08:18 AM   #222 (permalink)
XxToKeSxX
XxToKeSxX's Avatar
Trader Rating: 42 (100%)
I forgot to post these... this was my baseline dyno when I went to IPS for the first time... This was back when I had no mods done... just to get the car running.
Now I'm a little more upgraded than this but here it is for the people just starting to get into the turbo world and on a budget.
You can have 211whp/220ft-lbs with less than $1500 invested.
All runs were stopped before 6k, and they were all done at 10psi... temp was 88 degrees or so, with about 21% humidity back in June/July... the spikes registered as max boost so back off... and they were all done less than 12 minutes off the road from Cincinnati to Columbus so BACK OFF! Real time Numbers rock
Stock u12 Bluebird DET (8.5:1 Compression)
Stock Top Mount Intercooler Piping
Stock 370cc Injectors
Stock u13 ECU
Stock GTIR MAF
2.5" Reduction Bent JGY Downpipe
2" Greddy SP N/A Exhaust w/ a stock cat (restrictive exhaust ftw)
Poorman's (Ballin on a Budget) MBC set for 10lbs (spikes at 4k lil bit )
Lastly a Walbro 255hp on Stock FPR
1998 SE-R | S3Rs/I/H/E/M | 99.9% Daily Driver | Rubí DeL FuegO
1991 nX-T | My Boost Slut | 00.1% Daily Driver | The Deviled Egg
Shift_Down to 2 Vehicles...
Old 10-30-2007, 12:06 AM   #223 (permalink)
Harris
Coropate greed hater
My old setup:
RWD SR20DET
GT2871R with .64 A/R turbine housing
850cc injectors
HKS 264/264 Step I cams
300ZX TT MAF
3" turbo back exhaust
3" test pipe
Turbonetics BOV
Walbro 255lph fuel pump
Enthalpy ECU
I made only 330hp and 322 lb-ft tq at 20 psi with boost falling off rapidly to 15 psi (no idea why) as I progressed to redline. A/F goes lean initially, but quickly shifts mode to the comfort zone. Not happy with the power the turbo made.
Direct link for better view:
http://www.sr20forum.com/gallery/data/500/dyno_run.jpg
My new setup should yield better results, which is as follows:
RWD SR20DET
850cc injectors
300ZX TT MAF
3" test pipe
O2 induction intake manifold with Q45 TB
300ZX TT pistons
Cometic 87mm headgasket
TurboXS RFL BOV
Enthalpy ECU
I'm really hoping the new setup will yield my goal to get as close to 400 whp as possible.
-The Usual Suspects
Old 11-04-2007, 10:47 PM   #224 (permalink)
gtlaw
SE-R Newbie 4-life
GTI-r swap
3" downpipe & exhaust with a cat
JWT ecu
cobra MAF
14 psi
safc
I think all that choppy stuff was the pickup losing the tach signal
I'm probably going to tune for 18 psi soon
gtlaw is online now   Reply With Quote
Old 11-05-2007, 10:45 PM   #225 (permalink)
evilempire18
how about a dyno run?
evilempire18 is offline   Reply With Quote
Old 11-06-2007, 01:55 AM   #226 (permalink)
insane imports
engine #4 and counting
Looks damn nice but what were the #'s?????? Turbo set up consits of?
93 electric blue nx2000 with lots o mods.
91 g20 5spd dd soon to have t25 set up
99 maxima se 5spd: I/H/E
06 suzuki ltz 400 w/mods
cardomain.com/id/insaneimport2000
insane imports is offline   Reply With Quote
Old 11-19-2007, 02:44 PM   #227 (permalink)
trblsme2k2
Rebuilding again....
Uhh, numbers and setup?
SR20VE on Naawwwsss......
trblsme2k2 is offline   Reply With Quote
Old 12-01-2007, 12:47 AM   #228 (permalink)
evilempire18
its a git-r only bottom end mods no head work done... 571whp 26 psi haltech stand alone
Old 12-01-2007, 12:49 AM   #229 (permalink)
evilempire18
pt70 with a q trim 86 back, home made exhaust manifold
full aeromotive fuel system
haltech
thats about it
Old 12-01-2007, 12:55 AM   #230 (permalink)
El Verdugo
Bad ass numbers evilempire, say man what EMS is that a E6x or a E8? Congrats on the numbers.
Alberto
Old 12-01-2007, 01:35 AM   #231 (permalink)
se-riousclassic
the fo do
haltech
thats about it
I hear a little compressor surge in the dyno vid
99 SE-L
91 intake cam/bluebird t25/Calum ecu/370cc injectors/walbro 190/3inch dp/Greddy Catback/JWT PP w/ SE Disc/Prothane mounts
se-riousclassic is offline   Reply With Quote
Old 12-27-2007, 10:24 AM   #232 (permalink)
Daniel 100NX
The Flying Dutchman
Finally went to the dynojet today:
207.1 WHP - 225.5 Torque.
Mods are in my sig, but its basicly an U13 SR20DET with full 3" exhaust and boost @ 10 PSI
Next I'm gonna put the S4's in and dyno again. Should be around 240 WHP I guess
...and play a bit with the a/f ratio stuff, cause it's drowning at 5000 rpm
NX2000 TURBO
U13 SR20DET, JWT S4 cams, JWT ECU, 3" exhaust, JGY 6-puck clutch, Forge BOV, TurboSmart MBC, Custom FMIC, Walbro 255 FP, Nismo AFPR, K-Sport coilovers => 229WHP/250TQ
http://www.mijnalbum.nl/Album=O864ZWP8
Daniel 100NX is offline   Reply With Quote
Old 05-30-2008, 03:01 PM   #233 (permalink)
Daniel 100NX
The Flying Dutchman
Dyno'd again. This time with the S4 cams:
229 whp/250 tq
Old 05-30-2008, 03:16 PM   #234 (permalink)
MR-4Door-SR20DE
Weekend Warrior
Trader Rating: 32 (100%)
^Yeeeeeeeeeaaaaaaaaah Maaaaan! That was funny.
BEND BUT DON'T BREAK
93 SE-R "The Daily Re-Up" Is In Progress
Project-4Door-B13 "Building it one paycheck at a time"
FB1 - FB2 - SR20 storage building part-out LINK
MR-4Door-SR20DE is offline   Reply With Quote
