s4/s5 cam combo - SR20 Forum
Old 07-04-2004, 02:00 PM   #1 (permalink)
Feedback Score: 7 reviews
s4/s5 cam combo
i have heard of ppl running s3/s4 cam combo in turbo setups. i wonder how the s4/s5 will run? 12.8mm lift sounds tempting!
nite-stalker is offline   Reply With Quote
Old 07-08-2004, 11:15 PM   #2 (permalink)
Re: s4/s5 cam combo
how much better are aftermarket cams than the regular ones in a det doesnt the turbo do all the work how much could cams actually do
solotop186 is offline   Reply With Quote
Old 07-08-2004, 11:19 PM   #3 (permalink)
shift_boost
Feedback Score: 13 reviews
Re: s4/s5 cam combo
^^^^^^^^^ you should search solo
as far as the cam q i have no idea pm choderboy mike kojoma
myspace
03 blue by you evo 8 you know its modded
twisted200ser is offline   Reply With Quote
Old 07-09-2004, 03:01 AM   #4 (permalink)
SE-R GREEK
Feedback Score: 8 reviews
Re: s4/s5 cam combo
A lot better. Indeed, search this forum for dyno numbers of cam-med turbos. +30whp is common.
Chris
Old 07-09-2004, 03:03 AM   #5 (permalink)
SE-R GREEK
Re: s4/s5 cam combo
No-one has done it so no-one knows for sure.
SR20DE(T) seem not to like different intake and exhaust cams.
So, what type of combo do you have in mind? S4 intake, S5 exhaust?
Chris
Old 07-09-2004, 03:18 AM   #6 (permalink)
GT2835R
Re: s4/s5 cam combo
definitely
Rey Uy
99 SE-Limited
Old 07-09-2004, 09:19 AM   #7 (permalink)
Re: s4/s5 cam combo
I've heard of people running staggered cams with nitrous, but not with turbo.
1991 Classic SE-R
2003 VW GTI 1.8t
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Burke
"A foolish consistency is the hobgoblin of little minds ... " - Ralph Waldo Emerson
2xSE-R is offline   Reply With Quote
Old 07-09-2004, 11:01 AM   #8 (permalink)
Tired Greasemonkey
Re: s4/s5 cam combo
i suggest researching the concept and functionality of a camshaft, i don't want to sound like an ass, but anytime you mechanically allow more air/duration to a 4-stroke motor whether turbo,supercharged,nitrous, whatever it'll net you more horsepower/torque ESPECIALLY on turbo motors.
Old 07-09-2004, 12:25 PM   #9 (permalink)
70/30 Racing
Rockwood's Avatar
Re: s4/s5 cam combo
no.
if you increase lift, you will increase power on a turbo car. on a turbo car, unless it has a monster turbo, increased overlap (generally a product of increased duration) will more than likely reduce power. if you got these cams, youre going to want to reduce overlap to a minimum unless youre running a monster turbo (my turbo would be the minimum).
but, since youre asking, you probably dont really know how, or have the resources to do this kind of testing, so my suggestion is to stick with what is known to work: S3s or S4s with 2.5* retard on intake and 2.5* advance on exhaust. this would close up your overlap nicely, spool your turbo faster and fatten up the midrange. another good combo is some C1s with similiar cam timing, but they require valve springs, and every motor is different, so i would use that cam timing as a starting point.
with the S4/S5 combo, you could sit on the dyno for hours (at, what, $200 an hour? ouch!) and do nothing but lose power and have a nice, lazy turbo.
MotoIQ Project G20:
