Old 11-22-2004, 03:21 PM   #81 (permalink)
myprojectB13
myprojectB13's Avatar
Trader Rating: 16 (100%)
Originally Posted by SR20Turbofreak
DOH! i for got about that... the P11 throw out fork uses a bushing at the bottom of the shaft. the P10, B13 doesn't use a bushing. You need to somehow get the bushing out of there or grind the shaft down...
Thanks for reminding me of this. I think i just pushed the bushing out of the hole. don't remember how but i did..
It was cast into the bell housing on the trans I used. I tried beating on it a bit but it didn't budge. Its really not hard to grind the shaft down though. A write up coming soon I swear.
Jonathon
1996 G20
1993 SE-R 13.66@101
Old 11-23-2004, 12:05 PM   #82 (permalink)
myprojectB13
B13 clutch arm (left) vs. P11 hydraulic clutch arm (right)
Here's how I modified it:
Old 11-23-2004, 12:56 PM   #83 (permalink)
BadAzzSentra
No SR20 Power
Tranny's
On #4 tranny, broke 3rd all 3 times while shifting into 3rd, smooths the gears off on both shafts. was probably hitting around 15-17psi when the shift was made.
T3/TO4E @ 22 psi. (high boost) all 3 trannys were stock.
04' Spec V NX 75 Shot (Wet)
72' VW Bug 2180cc Stroker- Turbo Soon
02' Kawasaki Mean Streak - Kandy Gold Spark & Loud Pipes
91' SE-R : The BEAST in the SouthEast....Sold to Rodney
93' NX 2000 :.... Sold to Rodney
BadAzzSentra is offline   Reply With Quote
Old 11-23-2004, 01:16 PM   #84 (permalink)
yingtiry
Trader Rating: 7 (89%)
i don't know if the B15 trans is different but the P11 trans bolts right in after you change the Throw out shaft, the axles, flywheel, bellhousing bolts, there's even the holes drilled and tapped for the drivers side trans mount. the shift linkage is different where it goes into the transmission but it lines up perfectly, the shifter stabilizer on the P11 bolts to the transmission and on our cars bolts to the rear motor mount. just remove the bracket on the trans and keep the stabilizer attached to the rear mount. IT SERIOUSLY BOLTS RIGHT IN. try it....
So will also need b15 axles, and throw out shaft?
yingtiry is offline   Reply With Quote
Old 11-23-2004, 01:41 PM   #85 (permalink)
myprojectB13
No you don't need axles. You need the trans and a grinder to make a few modifications to the clutch arm you already have, see my above post.
Old 11-23-2004, 02:26 PM   #86 (permalink)
yingtiry
ok cool deal. so overall it was pretty easy then it sounds like. Did you pull your whole motor when swaping the trans or did you just drop the trans?
Old 11-23-2004, 04:30 PM   #87 (permalink)
Slow 96R
GTIRoids
Trader Rating: 62 (100%)
Ha ha, I can tell your new Just pull the trans. Hey myrpojectB13, did you have to grind that little black bracket for the shifter stablizer?
Tec 3+ B15 trans +???
Slow 96R is offline   Reply With Quote
Old 11-24-2004, 07:31 AM   #88 (permalink)
myprojectB13
Yeah I took a chunk off the stabalizer bar and a little off the shifter rod.
Old 11-24-2004, 10:06 AM   #89 (permalink)
lshadoff
Old School
Auto trans. 4 years 7 months turbo (HotShot kit with T3). 6.5# on the street, 9# at the strip with JWT nitrous off the line. No gears broken. Burned out the stock clutch packs in 18 months. Level 10 rebuild with no problems since then.
Lew
lshadoff is offline   Reply With Quote
Old 11-24-2004, 10:46 AM   #90 (permalink)
nismo91
little Thunder
nismo91's Avatar
T25 w/S3 cams, 10psi (low), 15psi (high) = NO broken tranny. Three years and counting....
Jonathon I"ll be waiting for your write up!
= Steve Lotho =
= = 91 Classic = =
= = Forum Rules = =
nismo91 is offline   Reply With Quote
Old 11-24-2004, 10:50 AM   #91 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 40 (100%)
You must drive like a Grandma Steve!! That is what they tell me anyway! LOL!
Brent
Old 11-25-2004, 09:14 AM   #92 (permalink)
nismo91
little Thunder
nismo91's Avatar
LOL! I shift with my cane...!
Brent
Old 11-26-2004, 03:47 AM   #93 (permalink)
insane imports
engine #4 and counting
Me too i have 20k+ turbo miles on my nx with no problems! Stock trans with clutch specialties stg 3 6puck clutch and stock flywheel.
Later,Jon
93 electric blue nx2000 with lots o mods.
91 g20 5spd dd soon to have t25 set up
99 maxima se 5spd: I/H/E
06 suzuki ltz 400 w/mods
cardomain.com/id/insaneimport2000
insane imports is offline   Reply With Quote
Old 11-28-2004, 09:01 PM   #94 (permalink)
psi999
N12 ET Pulsar GTIR swap
Has anyone here ever run a 50A box?.... its basically the same as a GTiR externally, but without the RWD extension.
Its very similar internally to the GTiR box, big gears and shafts (25.5mm input shaft as well)….. much larger than the 32V
I'm running this box, was curious if anyone else has gone this way.
RNN14 GTIR powered N12 Pulsar conversion
GT3040 turbo
Microtech
N20
custom everything
psi999 is offline   Reply With Quote
Old 02-20-2008, 10:48 AM   #95 (permalink)
unijabnx2000
where do i put it?
GT28RS --- 13psi --- 3rd gear sheared
1992 NX2000 GT28RS
i love HO alternators
Old 02-20-2008, 11:11 AM   #96 (permalink)
esevo
gt2871rs at 15-18 psi
With 155k miles on it!
No broken trannies!!!
I think its a clutch choice.
esevo is offline   Reply With Quote
Old 02-24-2008, 03:51 AM   #97 (permalink)
Coheed
Technician and Enthusiast
98 SE DET sentra. 91 ser tranny, gt28rs 19psi, six puck, about 340whp. Still holding, but clutch is slipping.
99 SEL VE-T 17psi gt3076r, six puck clutch specialties, p11 trans. maybe 350whp or so. Still takes a beating without a hitch. I bomb the thing in third while still in boost and so far this tranny has been awesome, but I can just barely break the tires loose in third. It has a lot better traction on the newer lsd it seems than the 98 sentra.
Coheed is offline   Reply With Quote
Old 02-24-2008, 04:34 AM   #98 (permalink)
NX2000DE
Shift_EGG
Avenir motor T25 @ 12psi JGY 380lb clutch no breaky tranny hopefully!!!
NX my anti honda and mitsubishi and ford
NX2000DE is offline   Reply With Quote
