Go Back   SR20 Forum > Classifieds > Wheels & Tires
Old 05-12-2006, 01:06 PM   #1 (permalink)
Phillies Are 08 Champs
Trader Rating: 42 (100%)
FS: 59mm Aluminum Hub Rings
Set of 4 BRAND NEW, NEVER USED blue aluminum hub rings for aftermarket wheels that have 70mm opening. Will come with locking rings that locks into place when rings are placed on back of wheel. Good for anyone buying aftermarket wheels that came off Hondas, VWs, Toyotas or Mazdas, which uses smaller diameter hub rings for aftermarket wheels. Asking $20 shipped, non-CC/debit Paypal accepted.
Note: If your aftermarket wheels came from the factory with an opening higher than 70mm, these will not fit.
Actual pic of rings:
59mm stamped on rings:
JET
96 QM1 SE-R, VE swap in progress
98 AL0 SENTRA GLE VE
92 AH3 SE-R ***SOLD 5/25/08***
GO PHILLIES!!!!!
2008 WORLD SERIES CHAMPIONS
sr20jet is offline   Reply With Quote
Old 05-17-2006, 05:26 PM   #2 (permalink)
wants to go play
Blair's Avatar
I'm interested, I just need to measure the wheels when I get home.
93 SE-R (daily driver)
Old 05-21-2006, 12:55 AM   #3 (permalink)
Still have them, just LMK.
Old 05-21-2006, 01:26 AM   #4 (permalink)
My Ass, your face
vladha's Avatar
What are these supposed to do, if you don't mind my asking? I have set that I used to use, but I figured that once the bolts are tightened, they weren't doing anything... took them off.
Peace,
Mark
vladha is offline   Reply With Quote
Old 05-21-2006, 10:28 AM   #5 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
Peace,
Mark
They space your wheel out by whatever thickness they are to reduce any rubbing, and/or they increase the center bore of the wheel - when you take off the wheels, you will see the "lip" that the wheel fits on. If the wheels you have (generic not your Enkei's) have a smaller gap than your hub, then the wheels won't fit over that lip. Does that make sense?
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 05-22-2006, 09:59 AM   #6 (permalink)
Peace,
Mark
The use of hub rings allows the wheels to fit snuggly on the wheel hub. Without the use of a correct hub ring(59 mm for most Nissan's), you can encounter while driving either wheel vibration or bending/added stress on the wheel studs. Most aftermarket wheels come with either a 70mm or 73mm wheel center opening, the use of hub rings for a specific car allows the aftermarket wheels to be correctly mounted. Hope this answers your question.
