these are 15x8 fly stars in good shape they are 4-114 but you can drill out the spacers on the rim for 4-100 or I has a set of alumuinum adapters with drag studs on for extra. the rims are 280 each I want $300 for both and 375 with adapters. about 6lb each. I was going to run 26x8x15in slick. email for pic muleman750@aol.com
97 200sx SE,electric water pump, GT35R,PROTECH equel lenght manifold,
stage v portedhead, ferria over sized valves ,je 10.4.1, cunningham rods ,total seal rings ,a1000 aeromotive fuel pump ,96lb injectors, o2 stage 2 ,Q45 t/b (90mm)
jun flywheel,clutch net pp with 4 puck ,3in exhaust,,jwt brain,PAR SYNCRO set,welded case
spearco ,kyb,S3,46mm tial,
