93 sentra se-r de+t - SR20 Forum
post #1 of 2 (permalink) Old 12-28-2018, 02:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
93 sentra se-r de+t
Hi guys ive had a couple nissans but now have had my sentra for 2 years and just now getting my project on its way. I want to turbo my sr20de and would like to know the best way to do this and hopefully acheive my goal of 250-300 horsepower. Right now i just finished the suspension and brakes, did the maf sparkplugs a few vacuum lines and intake and had to replace a fuel injector to get it running again. Id like to know options on best way to do this for price. I was thinking gtir intake mani and injectors maybe t28 turbo?? Im very knew to this and need all the knowledge i can get!
Kevin Glenn is offline
post #2 of 2 (permalink) Old 01-03-2019, 09:14 AM
Quoted: 0 Post(s)
I'm nearing the end of a similar project, but I'm also doing a full rebuild after I had some oil starvation and developed rod knock.
My goal is also 250+hp, and I've seen some reach 300 with similar components.
I'll PM you a link to the full photo dump, but here are some highlights:
https://www.reddit.com/r/projectcar/...ime_to_get_my/
https://www.reddit.com/r/projectcar/...entra_rebuilt/
https://www.reddit.com/r/projectcar/...the_block_for/
https://www.reddit.com/r/projectcar/...tra_continues/
https://www.reddit.com/r/projectcar/...ts_of/ed3ops0/
Parts list:
ACL Race Main/Rod/Thrust Bearings with Calico Coating .25 over
Resurfaced Crank
Remanufactured Head
Boiled/Magnaflux Block
Media Blasted Pistons (which cleared out some oil passages)
New NPR Piston Rings
Block Drilled/Tapped for Turbo Oil Return
New OEM Head Bolts
JWT S3 Cams
New Timing Kit including cam and crank gears
Cosworth 1.8mm Head Gasket
SR20VE Oil Pump with spacer
Pulsar GTIR Turbo Kit with manifold, journal bearing T28, and J-pipe
VDO Oil Temp, Oil Pressure, Water Temp Senders
Lightened Flywheel (13lb 1oz instead of the stock 18lb 9oz)
Action Clutch STAGE 3-1MS Clutch Kit
Autotech Motoring Oil Feed Line
650cc Sidefeed Injectors
Walbro Fuel Pump
E60 MAF
G Spec Performance Crank Pulley
JGY Water/PS/Alt Pulleys
2.5" IC Piping Kit
27"x7"x2.5" Front Mount Intercooler
JB Weld Stock Trans
Powdercoating
- OEM valve cover Red
- Upper Water Neck gloss White
- T28 compressor housing Red
If you want my suggestion to keep costs down, it's this:
Don't turbo your current engine. There are too many knock-on costs of doing this. For a budget build you shouldn't need to get a tunable ECU, which can cost half the price of a swap alone.
For a budget SR20DET FWD, buy a swap with OEM ECU and the Fueling/Air Metering components that match what the ECU expects.
Don't get me wrong, I'm super excited to get my car up and running and really see how it goes. But! I think I could have scratched my itch for more power by going SR20VE and staying NA.
vorin is offline
  SR20 Forum > Main Forums > New Members
User Tag List
