RETIRED SR20DE(t) Compression/HeadCode List - SR20 Forum
Closed Thread
post #1 of 82 (permalink) Old 05-12-2003, 02:24 AM Thread Starter
Shift_日産
Quoted: 0 Post(s)
Feedback Score: 5 reviews
(Thread Starter)
This is a post for pople trying to identify what engine they have...
Lets keep this to ONE POST PER PERSON UNLESS YOU NEED TO ADD SOMETHING. Make sure to include your USDM motors also. Also Inclued other markings on the head like 5R 1R 3L and such Tell alittle about your engine so we can get a list of what to look for in 10:1's and so on.. Pictures would be great also! Turbos will be added soon This list will be updated often!!!!
Head #'s
1N5 V1 - SR16VE
1N5 V2 - SR20VE
5J -
51N -
52F - Larger Exhaust Valves Silvia engine
53C - JDM Pulsar GTi-R. 8.3:1 T28 Turbo Low Imp. 444cc Injectors Larger Top Mount Intercooler Larger Oil Cooler Solid Lifters Ind. TB's Oil Squirters
53J V1 - USDM Black Channel Valve Cover Highport 9.5:1 1990-92 Red Injectors EGR OBD-1
53J V2 - 1R USDM Silver Valve Cover Highport 9.5:1 Red Injectors EGR OBD-1 1993 RIBS
53J V3 - 5R JDM Ribs on head Silver Valve Cover Red Injectors Mitsubu Alt. tubular ex. manifold 1/1 in circle and /5 in circle on head beside 53J
53J V4 - JDM Black Channel valve cover
53J V5 - JDM Silver Valve Cover No Ribs
53J V6 - BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB
53J V7 - JDM Black Channel valve cover tubular ex. manifold 10:1
53J V8 - 2L W11 Avenir 8.5:1 silver valve cover Ribs 370cc purple injectors T25 ball bearing turbo Big TPS No EGR Mitsu altenator High port Internal coil OBD-I Stock oil catch can steel pipe has a built in restrictor.........the one the runs from the valve cover forward then behind the distributor to the stock catch can. same BOV/CBV as teh 1stGen DSM
53J V9 - W10 weaker BOV then the W11 Non ball bearing turbo 8.5:1
53J V10 - 3L 10:1 JDM bare aluminum cover w/ black in the middle No Ribs under the coil there is a circle with a line through it and a small number 7
53J V11 - 2R I think this is a W10 BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB Red V/C black channel
53J V12 - 3L JDM Ribbed head, All silver valve cover, either a 6 or 9 and a 1 in circles under the coil.
53J V13 - 8R JDM with an 8 in a circle behind the coil bare aluminum vc tubular header external coil and egrless of course highport ribs on the side of head
53J V14 - 8L USDM Ribs 93 NX2000 All Silver Valve cover 9.5:1
54C - N14 Pulsar DET
54D -
58Y - SR18DE JDM highport.
64J - SR18DE SR18Di JDM lowport.
65J - 2R 2J2 10:1 JDM Silver valve cover
78E - BlueBird SR20DET (53J Head) Larger Exhaust Valves
79E - Larger Exhaust Valves
89H - SR20DE Silver Valve Cover U.K. '94 SLX P10 lowport No ribs 9.8:1?.
89J - SR20DE Red Valve Cover UK lowport sodium filled valves 10:1 Gray 259cc Injectors .
94Y V1 - 3L SR20DE US lowport 9.5:1 OBD-1 1994
94Y V2 - SR20DE US lowport 9.5:1 OBD-2 1995-99
96J - 1R UK Redtop 10:1 Highport (UK 101 1R 96J head)Gray 259cc Injectors Mitsubu Alt. sodium filled valves
Unknown - USDM B15 Roller Motor Nonpainted VC 9.5:1 OBD-2
Unknown V1 - AUTECH 11.5:1 175hp for Lucino Nonpainted VC
Unknown V2 - AUTECH 11.5:1 180hp for Primera Nonpainted VC
Unknown - 53J 4R, JDM 53J 3L, 53J 1R McRib USDM, 53J 4J???, 53J 4L
Cars With 10:1's or higher
Nissan 100Nx GTi
Nissan Sunny GTi
Nissan Almera 2.0 GTi
Nissan Almera Tino 2.0
Primera HNP11
Primera 2.0e HP10
Primera 2.0eGT (5 door) FHP10
Primera 2.0GT FHP11
Primera 2.0Te HP11
Primera 2.0T4 HNP10
Primera Wagon WHNP11
Nissan Primera Wagon 2.0 WHP11
Prairie Liberty GF-PNM12
Autech Sunny Lucino Version B13
Autech Lucino Version 3 door N14
Autech Pulsar SERIE Version N14
Pulsar GTi Autech version N14
Autech Primera 2.0e HP10
Tommy Kaira ZZ-S
Tommy Kaira ZZ
Nissan Avenir GF-PW11
Nissan PRESEA 1.8L R11
PLEASE KEEP IT TO ONE POST PER PERSON UNLESS YOU NEED 2 ADD SOMETHING
DESCRIBE YOUR ENGINE
Ribs on the head
1996 Nissan 200SX SE-R
クリストファー
•AT-MT B13-LSD swap •JWT P/P •2000SE Clutch Disc •Cusco FSTB •Hyperco Gen2 •Unorthodox 4 Pulley Set •HP Racing Header •Rota 16x7 Circuit 8 w/ BFGs •12Lbs.Flywheel •Injen CAI •Stillen POP Charger •B&M Short Shifter •91 Cam •Prothane Mounts •Magnaflow Muffler •Taylor 10mm Wires •Carbon Fiber Hood •Erebuni Body Kit •Black Healights w/ Amber corners •Redline MT90
AztekSE-R is offline
post #2 of 82 (permalink) Old 05-12-2003, 08:50 AM
CSERT MEMBER
Quoted: 0 Post(s)
Feedback Score: 4 reviews
W11 Avenir
8.5:1
53J
silver valve cover
Ribs(i assume on the side of the head)
Big TPS
No EGR (of course)
Mitsu altenator
High port
Internal coil
OBD-I
I think thats it
Give me your tears gypsy or I will take them from you
Carlos
74 Datsun B210
93 Black SE-R
99 G20
93BlackBird is offline
post #3 of 82 (permalink) Old 05-12-2003, 12:16 PM Thread Starter
Shift_日産
Quoted: 0 Post(s)
(Thread Starter)
well are you guys going to add to this??????
This is My New JDM SR20DE
Ribs on the head
Mitsubu Alternator
External Coil
All Silver Valve Cover
53J On the head
Distrib facing the fire wall
Big TPS
Auto Tranny
Highport
red injectors
NO egr
5R on the head (distrib side)
tubular exhaust manifold
クリストファー
post #4 of 82 (permalink) Old 05-12-2003, 12:28 PM
..word..
Quoted: 0 Post(s)
Feedback Score: 3 reviews
tsk tsk tsk
...1 post per person...
asdf
Daley is offline
post #5 of 82 (permalink) Old 05-12-2003, 12:29 PM
Quoted: 0 Post(s)
W11 Avenir
8.5:1
53J
2L under distributor
silver valve cover
Big TPS
No EGR (of course)
Mitsu altenator
High port
Internal coil
OBD-I
*Stock oil catch can steel pipe has a built in restrictor.........the one the runs from the valve cover forward then behind the distributor to the stock catch can.
NOTE: My USDM SR20DE does not have this, as well as Bluebird SR20DET's I believe, only Avenirs has this, can anyone confirm for sure if the Bluebird has this?
charlie2020 is offline
post #6 of 82 (permalink) Old 05-12-2003, 01:41 PM
Quoted: 0 Post(s)
JDM Nissan Primera
10:1
65J
Silver valve cover
STOCK.
CarloSR is offline
post #7 of 82 (permalink) Old 05-13-2003, 02:11 AM Thread Starter
Shift_日産
Quoted: 0 Post(s)
(Thread Starter)
UGGGG!!!! Guys how are we going to figure this out if no one contributes?
クリストファー
post #8 of 82 (permalink) Old 05-13-2003, 05:24 AM
SE-R GREEK
Quoted: 0 Post(s)
Feedback Score: 8 reviews
Give it sometime....
Not all of us in here have time NOW....
Chris
hpro123 is offline
post #9 of 82 (permalink) Old 05-13-2003, 08:43 PM
SE-R driver since 1994
Quoted: 0 Post(s)
Feedback Score: 22 reviews
My Bluebird has it.... I noticed it when cleaning things up before the install.
[B] '92 SE-R - New project! '08 Infiniti M35 - Wife's DD - '00 Infiniti G20 - My DD
Turbo91SER is offline
post #10 of 82 (permalink) Old 05-13-2003, 09:58 PM
Quoted: 0 Post(s)
I just went to double check mine before I posted I think I told you what I had was different than it is. Like I said though it already had the us manifold swapped on as it was in another forum members car for a week before he took it out for a DET. Mine is a 53J 3L silver cover black stripe, No ribs on the head. My USDM was a 53J 1R w/ ribs. What about numbers on the fronts of the motor? I also noticed a couple other castings elsewhere like under the coil there is a circle with a line through it and a small number 7. on the front there is a small M in a circle. Andreas Miko told me once that these numbers like 1R, 3L, 4J are just stampings in the block to tell which line they came off of so if there where a problem they could trace other motors from the same line. But I'm not positive we do need to figure it out though.
Nick McCollom
99 Infiniti G20
93 Nissan NX2000 14.027 @97.98 (N/A) I wish I had time and money again, this little car has sat for 2 years now. I do miss driving it bad. It will be back soon though faster than ever.
http://www.cincyclubclub.com/lilly/littlefamily.jpg
sakerocket1 is offline
post #11 of 82 (permalink) Old 05-14-2003, 12:29 AM Thread Starter
Shift_日産
Quoted: 0 Post(s)
(Thread Starter)
so far so good all the engines have a different head # except the USDM and the UK one so far
クリストファー
post #12 of 82 (permalink) Old 05-15-2003, 02:25 AM Thread Starter
Shift_日産
Quoted: 0 Post(s)
(Thread Starter)
BTT
OK all i really need is what engine it is Head # (like 53J) and the head code (like 4L) valve cover details. If its JDM or USDM (if its USDM let me know what year)
PLEASE PLEASE Add to this it only takes 2 mis to look at the head for this info...............
クリストファー
post #13 of 82 (permalink) Old 05-15-2003, 08:15 AM
i love me some SR20
Quoted: 0 Post(s)
Feedback Score: 13 reviews
i have a JDM motor, 53J 3L.... and the valve cover that came with it was a polished GTi-R VC so i dont know....
oh and what are the #s on front of the block right by the tranny and under the spot that says SR20 mean???those might mean something...
93 Black SE-R VE
95 240sx RB26 601 whp (sold)
92 Super Black Puslar GTi-R(sold)
12.41 @ 115
civicsRslow is offline
post #14 of 82 (permalink) Old 05-15-2003, 11:22 AM Thread Starter
Shift_日産
Quoted: 0 Post(s)
(Thread Starter)
Does your engine have the ribs on the front of the head
Does it sound like this one
クリストファー
post #15 of 82 (permalink) Old 05-15-2003, 03:36 PM
i love me some SR20
Quoted: 0 Post(s)
yeah it has the ribs.... and there is a circle with a line through it by the coil but i dont know about a 7 i will look later...
93 Black SE-R VE
12.41 @ 115
post #16 of 82 (permalink) Old 05-15-2003, 04:50 PM Thread Starter
Shift_日産
Quoted: 0 Post(s)
(Thread Starter)
well humm this so far is the first one that has the same head design but different discription
クリストファー
post #17 of 82 (permalink) Old 05-15-2003, 09:05 PM
Quoted: 0 Post(s)
here we go
JDM 53J 3L, Ribbed head, All silver valve cover, either a 6 or 9 and a 1 in circles under the coil. That fits none of the thus described engines.
I'll add USDM #s tomorrow (its like a monsoon right now and I might melt )
mc0029 is offline
post #18 of 82 (permalink) Old 05-15-2003, 09:43 PM Thread Starter
Shift_日産
Quoted: 0 Post(s)
(Thread Starter)
added 2 new engines
クリストファー
post #19 of 82 (permalink) Old 05-16-2003, 02:45 AM
Quoted: 0 Post(s)
i have a rwd sr20de...
52f head...from s13 silvia i think...
here in the Phil...they released the nissan Serena(mini van) with an sr20de...150hp...it has silver cover, looks like a low port to me...and it has stripes on the valve cover i think...dunno the head stamp
and they said its code was SR20M...hmm interesting..
a VE, still a dream for now...
b12sr20ve is offline
post #20 of 82 (permalink) Old 05-16-2003, 03:41 PM
Quoted: 0 Post(s)
My U.K. '94 SLX P10 low port Primera is a 89H but has a silver head cover. No ribs and supposed to be 9.8:1.
SteveB is offline
Closed Thread
  SR20 Forum > Main Forums > SR20DE Technical Corner
User Tag List
