Modifying b14 distributor - SR20 Forum
post #1 of 14 (permalink) Old 03-18-2004, 02:24 AM Thread Starter
SE-R BUM
Quoted: 0 Post(s)
(Thread Starter)
I am installing my RPM triggers and i am having problems getting the center bolt off of the rotor support... it feels like it is on there tight and it seems like im stripping it with my screwdriver. Im using a flat head cause the philp doesnt seem to grab as good as the flat head screw driver.
Do you guys have any tips on getting this sucker loose, so i can complete wiring up my msd triggers?
thanks
(New all motor) 96 B14: Sr20VE JWT ECU, Msd switches, ES mounts and Bushings,2.25 stomung exhaust, KYB shocks, Eibach Sportlines, NGK Plugs/wires, ACT HDPP & Street disc, Hotshot CAI & Headers gen. 5,N-1 intake mani/TB,thermo spacers, B15 LSD trans, AEB1 GEN. 1 Header...
BEAST is offline
post #2 of 14 (permalink) Old 03-19-2004, 12:32 AM Thread Starter
SE-R BUM
Quoted: 0 Post(s)
(Thread Starter)
Re: Modifying b14 distributor
oops stripped the hell out of it... probably need a whole new distributor... should i drill at it so i can get that bolt out... HELP! Please!
thanks
BEAST is offline
post #3 of 14 (permalink) Old 03-19-2004, 01:32 AM
banned
Quoted: 0 Post(s)
Feedback Score: 5 reviews
U got PM
charlie2020 is offline
post #4 of 14 (permalink) Old 03-19-2004, 01:53 AM
banned
Quoted: 0 Post(s)
I got a question is it possible to make a B14 Internal coil distributor work on a B13? If u know how to I'll hook u up with a B14 distributor for $20
post #5 of 14 (permalink) Old 04-09-2004, 05:53 AM Thread Starter
SE-R BUM
Quoted: 0 Post(s)
(Thread Starter)
well i got the damn stripped bolt out of the distributor... and continued with the modification of the b14 distributor. I cut the third metal clip (dont know what its called) and solder the wire to it and put everything back together. hooked it up to my ve motor and msd tiggers. turn the key and now my motor wont start...(car was running without solenoids activated)
is there another wire that im suppose to cut like a resistor or something?
i tried to get directions from JWT but my computer sucks and wont download the directions.
someone please help!
i need the vvl power
BEAST is offline
post #6 of 14 (permalink) Old 04-09-2004, 08:05 AM
Quoted: 0 Post(s)
Feedback Score: 12 reviews
You made a mistake. You did the modification to install a MSD ignition not a MSD RPM switch. To install a switch you only need to splice into the wire that goes into the distributor. You don't even need to open it up. Once you cut that brass plate you need to solder a wire on that tab and that wire goes to the new ignition.
Steve
98sr20ve is offline
post #7 of 14 (permalink) Old 04-09-2004, 09:40 AM
Jah Rastafari
Quoted: 0 Post(s)
Feedback Score: 61 reviews
Yes it is very easy, get a 200sx diagram for the dist and one for a B13 and you will be set. Its just like putting a VE dist which is basiclly the same as a 200sx dist on a B14. I have done a few of the the Ve dist on a B13 so it should be straight forward
Andreas Miko is offline
post #8 of 14 (permalink) Old 04-09-2004, 12:48 PM
banned
Quoted: 0 Post(s)
Thanks Andreas, now I need to get both manuals but I got a few more questions for you, when doing the transformation I do loose the B13 external coil right becuase that will be somehow wired into the B14 distributor right...........and wont I loose the Ignition Control Module (ICM), because that to will also be wired into the B14 distributor also or no?.
P.S. Last time I took a count of all the b13 wires I believe would be involved in the swap was like (9 total)......(4) distributor, (2) coil, (3) ICM (is teh ICM involved?
The B14 has (7) on the distributor........................does the B14 have a ICM also?
Thanks in advance
post #9 of 14 (permalink) Old 04-09-2004, 12:51 PM
banned
Quoted: 0 Post(s)
It looks like i will be short 1 wire on the B13 harness if only the distributor and coil or used and plus 2 wires if the ICM is involved being that the B14 distributor only has a place for 7 wires.
post #10 of 14 (permalink) Old 04-09-2004, 07:45 PM Thread Starter
SE-R BUM
Quoted: 0 Post(s)
(Thread Starter)
great! now i just made it harder for myself! ... well need to solder that back together.
the wire you are suppose to splice... what color is it... is coming from the harness (7) prong or (2) prong connector or is it that single black one that is on the side of the distributor?
BEAST is offline
post #11 of 14 (permalink) Old 04-09-2004, 07:55 PM Thread Starter
SE-R BUM
Quoted: 0 Post(s)
(Thread Starter)
Nevermind i think i answered my on question
blue wire on the long plug... right?
if so, im a dumb ass for not reading the sticky right!
BEAST is offline
post #12 of 14 (permalink) Old 04-10-2004, 08:04 AM
Quoted: 0 Post(s)
Uhmmmmmm
Steve
98sr20ve is offline
post #13 of 14 (permalink) Old 04-10-2004, 11:43 PM Thread Starter
SE-R BUM
Quoted: 0 Post(s)
(Thread Starter)
well it looks like im right cause it works and it feels a lot better... feels like a beast!
but i got one more question for the absent minded... if im facing the motor from the front which solenoid is powering the intake and exhaust?
BEAST is offline
post #14 of 14 (permalink) Old 04-11-2004, 01:03 AM
eric96ser's Avatar
Quoted: 0 Post(s)
Feedback Score: 29 reviews
Intake is on the left(brown), exhaust on the right(green).
The community is here.
eric96ser is offline
  SR20 Forum > Main Forums > SR20VE / SR16VE
User Tag List
