1 - 20 of 91 Posts
'The Sleeper'
Well guys, I'd like to thank you all for all your advice on how to run quicker in the 1/4!
Yesterday at Crail Raceway - U.K., I managed to run an all time PB of...
13.969 secs @ 98.5 mph (without nitrous assist.)
This is all thanks to a revised suspension setup and proper tyres!
Thanks again guys!!!
Cheers
Dave :cool:
P.S. How does this time rate as an SR20DE without nitrous?
SR20VE or a T28? I dunno!
Wow. Mod list please!
yea man tell us exactly everything, everyone is going to be really interested, I assume some weight reductions too
'The Sleeper'
Discussion Starter · #6 · (Edited)
Yeah, no problems guys...
98 SR20DE Block
Outrun P&P ‘92 High Port Cylinder Head
UKDM Flat Top Pistons
11.1:1 Compression Ratio
Dastek Unichip (Mapped live on DASTEK Dynomometer)
Dastek Rev Limit Module (8000 rpm Fuel Cut-out)
Dastek Nitrous Driver Module
BMC Carbon Fibre Intake Housing w/ RAM Pipe
Ceramic Coated Gen. 5 Hotshot Header w/ Thermal Wrap
Outrun 2.5” Stainless Steel Exhaust (Internally Polished)
Outrun 2.5” De-cat Pipe (Internally Polished)
Outrun Polished Intake Manifold
CCR Stainless Steel Muffler w/ 4” Slash Tip
Piper 'Fast Road' Camshafts
HKS Adjustable Camshaft Sprockets
Unorthodox Racing Pulleys
HKS Iridium Spark Plugs (Grade 8)
Skyline GTS-25t Fuel Pump
FSE Fuel Regulator
Fidanza Flywheel
B&M Shoft Shifter
ACT HD Pressure Plate
ACT Performance Street Disc
O.Z. Racing Superleggera (15x7 F, 17x7 R)
195/55R15 Yokohama AO48 Advan Tyres (Front)
205/40R17 Toyo Proxes T1-S (Rear)
P.I. 40mm Pro. Rate Springs w/ Koni Adjustable Dampers
Current vehicle weight with driver - 2445.4 lbs!!!
239 hp @ 7000 rpm
196 lbft @ 5500 rpm
Both flywheel figures calculated from 16% trans. loss at DASTEK UK dynamometer!
Cheers
Dave :cool:
'The Sleeper'
You will be able to view the days times for the car at...
http://www.crailraceway.co.uk/entrants.asp
as soon as they update the times for the day!!!
60ft time was 2.161 secs
Cheers
Dave :cool:
P.S. I will be under "D Bull (19)"
You may have to wait for them to update the site though, as they are still displaying the times for the 22nd February!!! :rolleyes:
Dastek? I never heard of them, are they cheaper then JWT with there ECU's? Do they have a website? Thanks
JordanWhiteMusic.com
Seeing that he listed his mods as:
I'd pretty much bet that was more expensive than the standard JWT ECU.
Jah Rastafari
SE-Rican said:
Awesome times bro!!
Did you dyno 239 whp all motor? If so that is badass!!
239 crank HP
Needs bigger cams, bigger exhaust. Still awesome times and dyno though, good going
Jah Rastafari
Your cars weight is 2445 pounds with driver. You ran 13.969 @ 98.5 MPH with a 2.161 60ft time. You say your car makes 239 HP with 196 lb ft torque. Which would be about 207 WHP with 166 LB ft torque.
My cars weight with driver is 2605 pounds. My car runs 13.983 @ 101.5 MPH with a 2.265 60 ft time. I made at the time 200 WHP with 155 LB ft torque.
My cars is 150 pounds heavier and runs 3 MPH faster in the 1/4 mile with the same 1/4 mile time.
If you do the math your car is making about 180 WHP with 148 LB ft torque.
Another exaple is Steve Foltz with the VE. He makes 189 WHP with 150 lb ft torque. His cars weight is about 2700 pounds with driver. He runs 14.3 @ 98 MPH with a 2.3 60 ft time.
Please dont get mad at my post I am just wondering if the measurement of HP is diffrent over in the UK.
Look at the figures side by side.
----------------------------------Me------------- You----------
Crank HP---------------------228 HP----------239 HP---------
WHP-------------------------200 WHP--------207 WHP-------
LB Ft Torque-------------------175--------------196---------
LB Ft Torque @ Wheels----155--------------171---------
Car with driver----------------2605 LB---------2445 LB--------
Peak HP----------------------7300 RPMs-------7000 RPMs----
Peak Torque------------------6300 RPMs-------5500 RPMs----
60 ft time---------------------2.265------------2.161---------
Trap Speed @ 1/4------------101.5------------- 98.5---------
1/4 mile time-----------------13.983------------13.969-------
Just a comparison, Please dont get mad.
1 - 20 of 91 Posts
