1 - 2 of 2 Posts
it starts when i use a jumper wire to the starter solenoid wire. i also checeked and the ignition switch is geting juice and sending juice out the wire to the starter (i believe its a b/y wire out of the switch and pigtail, to a b/w wire on the wiring harness under the dash). i hear a click or two one coming from the acc relay under the hood on the driver side. and a click under the dash too. Cehceked all the fuses. trying to figure out what is between the ignition switch and soleniod. I just swapped in a auto trans and i jumpped a grey connector by the relay box on the passenger side as they show on auto trans swap directions on the net. any help appreciated.
Discussion Starter #2
turned out i jumped the wires toegther on the wrong connector. it was the connector by the fuse box but i needed the one directly under it. now i got that fixed and now my relays buzzing for the ignition coil i hate electrical gremlins
1 - 2 of 2 Posts
