I'm having some money problems right now so this leads me into my Question.
Sat. I got a flat tire and it's non repairable so I've been riding around on a steel rim with a bigger tire size on that one side.
I wanted to know if this will cause any problems later down the road. I'm under the impression that it may mess up the lsd diff in the tranny. I don't know when I'm going to have the money to fix this problem seeing as I don't have a job and can't find one at the moment.
thanks you for any help
shift_boost
using different tire on the front will mess up your trans.
the different wheels spinning at different speeds the trans thinks your turning all the time, having to give more to one wheel causing heat.
