1995 nissan 200sx se-r. Sr20.
I am having some ignition trouble. The battery has a full charge and I recently replaced the alternator, so thats not the problem. When the key is turned in the ignition it just clicks. I initially thought it was the starter or solenoid, so I replaced it, but it still does it! Sometimes it will start on the second try, other times its take me five minutes to start it. I don't think the relay is bad, but I am starting to suspect faulty wiring somewhere. Any help/tips/suggestions would be appreciated.
Discussion Starter · #2 ·
O and i forgot to add:
When i took the old starter off i took it to the local autoparts store. The clerk tested it and said it was faulty because it required more for it to work. I'm not sure if this is related to the problem or not.
make sure everything is connected good.. i had a similar problem.. found out the the connector that goes in the alternator was loose.. also clean your battery terminals and alternator terminals....
