It really depends on how much power he wants. If he wants to stick with pump gas, the easiest thing to do is get a tubro/manifold setup off of either a Bluebird/Avenir DET with t25 or GTi-R mani w/ t28, 370cc injectors, Jim Wolf Technology(JWT) S3 cams, JWT Ecu (reprogrammed nissan ecu for whatever setup you want), bigger MAF, fuel pump, and you'll be good for 250-280whp. You can get most of these things used (Andreas Miko sells a lot of stuff). If you have the extra dough, you could splurge for the Garrett GT28RS Disco Potato turbo..... insane spoolup. Started with some Nissan guys using it, now the Audi guys are using it, and it's coming with turbo kits now too for civics.
If he wants more power on pump gas, he'll have to go DET for the lower compression. It's generally recommended to avoid the GTi-R due to parts availability (or lack thereof). Um... tons of info on this forum, and www.se-r.net
If you guys stick to the stock motor, the only slightly tricky thing to do is drill and tap the block. Tons of info on that. Check out jgycustoms for some parts. Also, Hotshot makes an IC kit that'll bolt right up if you don't feel like making your own piping. Um, tons of info on this forum.... try searching under turbo setups, etc.
