· Premium Member
I got a question for those of you that have taken apart a 20V motor. Does it have a full counterweighted crank and a girdle like an older pre roller DE? Or is it half counterweighted and no girdle like an early VE or roller DE.
Mike
· Jah Rastafari
Mike
I think I am the only one with a 20V motor so far. Mine has 2,000 Km on it. I am not sure what it is but the pully on it is diffrent from the older SR20VE motors. I was told that it is 8 counterweight. If you want I will pull of the black oil pan and check this weekend.
As far as the cranks go Nissan stoppd doing 4 counterweight cranks on the SR16VE motors. When they went to the N16 body they went 8 counterwight in th SR16VE motors. All the SR16VE motors that came with the cable box had 4 counterweight motors and all the Sr16VE motrs that came with hydralic gear boxes had 8 counterweight cranks.
· Premium Member
If you could find out for sure on the crank and girdle thing it would bew most helpful for my book, I need to anticipate these egines becoming more common.
Mike
