upgrade fuel system...370s, walbro fuel pump too..........progressive controller?
AaroNX said:Yeh I think he needs to understand the difference between a dry kit(like jwt program) and a DP kit.
I like this setup, thank you very much, but is this all that I need? I think I read that I'll need msd or something like this.NX direct port wet kit
NX progressive controller
Bottle heater
Nitrous gauge
EGT gauge
Purge
Walboro 255 lph
Slicks and/or drag radials
ACT HDPP SD Clutch
MSD is a window switch, which will allow you to floor it at a low rpm, and then have the nitrous kit in at say 4k rpms, and then it will turn it off before you hit the rev limiter.SE-R_Tj said:I like this setup, thank you very much, but is this all that I need? I think I read that I'll need msd or something like this.
a)The JWT set-up doesn't come with a nitrous kit, just the ecu.brian said:dude, just do the JWT full kit and you won't have to worry about
a)buying a kit
b)progressive controller
c)window switch
d)blowing your motor unless you do something really dumb
all you would have to do is buy a fuel pump to be save and some heat range 7 plugs and gap the crap out of them and you will be running good
My (~$1000) JWT nitrous kit came with a 50 shot dry NOS kit, the ECU daughter board for control, a relay and switch for arming the system and decent installation instructions. The ECU senses when the TPS is wide open and starts spraying.MARCUSMARC said:a)The JWT set-up doesn't come with a nitrous kit, just the ecu.
b)JWT doesn't not have a progressive contoller built in, If I were a JWT user, I would use one, especailly with a 100 shot...
c)Does the JWT ecu come with a window switch? I'm not sure about that one. In any case, if you have a progressive, you don't need a window switch.
d)I don't think the JWT upgrade comes with injectors.
and e) For 1000 bucks to JWT, I"m pretty sure ONLY get the ecu. What a rip off imo..
Or am I totally off, and their is a FULL kit now. How much is it, like $2000.
~ Marcus![]()
Ah, didn't realize you get a dry kit with it. In any case, I would feel much safer with a window switch/progressive controller.lshadoff said:My (~$1000) JWT nitrous kit came with a 50 shot dry NOS kit, the ECU daughter board for control, a relay and switch for arming the system and decent installation instructions. The ECU senses when the TPS is wide open and starts spraying.
You can see the installation here:
http://www.brazosport.edu/~lshadoff/turbo/nos.html
Lew
I sell the stuff, so I think I kinda know what I am talking about, no, you don't get injectors with it, and yes, thier full kit is expensive, but it is all intergrated and totally bad ass.MARCUSMARC said:a)The JWT set-up doesn't come with a nitrous kit, just the ecu.
~ Marcus![]()
