Resto 99% complete
Is the rear alignment of the 91-94 SE-Rs adjustable?
The reason i ask is that the inside of my rear tires are worn and it doesn't look like it's ever been adjusted.
thanks
Keith
_______
Yes, it's adjustable. Not as much range as the fronts of course, but it's probably possible to be out of spec enough to cause wear.
As for a guess, it's probably too much toe-out, and the inside edges of the tires are worn?
Resto 99% complete
Where does it adjust?
Only place i can see is the lower arms. Are there some adjustments on top too?
I have the Eibach Pro-kits with KYB AGX's.
Are there specs for lowered cars somewhere?
