Status
Not open for further replies.
5500 CASH COME AND GET IT!!!!!
1993 240sx Auto to 5 spd for sale
Interior:
S14 seats
New Aftermarket black carpet
All black.Grey interior pieces in excellent condition
Black dash with your usual hairline crack
Brand New Leather shift boot
Electronics:
Profec B Boost controller
Greddy turbo timer
Autometer Vac/Boost, water temp, and oil pressure in custom guage pod
Scott Avoy ROM Tune Ecu
Engine:
1- SR20det Red top
Tomei Head Gasket
Greddy RAS
Greddy Titanium springs
Greddy 3-piece pulley kit
Greddy Intake manifold port matched
Greddy Type R Bov
HKS 264 Step II Cams
Now has MSD 72lb injectors with a new rom tune ecu =)
Jgy Fuel rail
Aeromotive Fpr
Z32 MAF
Brand New water pump
Battery Relocated to trunk
Log manifold
Tial 38mm recirculated or you can divorce it
Precision SC61 Turbo, turbine housing has been ported and thermal coated black
Enjuku turbo blanket
Enjuku radiator plate
Poly filled motor mounts
Hybrid FMIC with custom intercooler piping powder coated black
Fluidine Aluminium Radiator
16" electric fan with thermal temp switch wired in
Brand new Kumho Tires
Tranny:
The case has been pressure washed inside and out with out the gears in it looks new
Has all new seals
Toda Chromoloy Flywheel
Custom 4-Puck Sprung hub Clutch w/ upgraded pressure plate Bay City CLutch
SS CLutch line upgrade
Poly filled tranny mounts
Aftermarket Short Shifter
Red Line Shock Proof Transmission fluid
5spd drive shaft connected to an OEM Vlsd
Exhaust:
3" Downpipe thermal coated black Sawyer Production
One off 3" Sawyer Production all the way back to a "oem" style looking magnaflow muffler high temp painted flat black
Everything has been done right on the car, its just an unfinished project and someone with some more time can finish the body work, there is no wing or wiper on the hatch couple dents here and there needs a better driver side fender and some paint, suspension and the car would be very sleeperish and clean. The car made 361 whp and 270 lbs tq @ 17psi uncorrected on pump gas remember this is an SC61.. Or just install a Full Race Mani and pick up 60 more whp at same boost level only things that dont work are the wipers and speedo, the ac is installed just never filled up. The car now runs much smoother with the 72lbers in it, she just needs a dyno session with Scott(Enthalpy) to fine tune his ROM ECU.
Car does need some body work and paint job, the car is ruby red with black fenders and front bumper
thanks TJ
813-789-1765
Status
