I was putting my avenir motor back togethr and when I put the sprockets back where they go, i marked them with a pen. I dindt line up the gold mark with the grank sprocket or the darker links with the cam sprockets. I kno that there are 11 links between both indents. 11 if you count the space between the pins. Before I pu the chain tensioner in there was slack, after I put the chain tensioner in there was less slack but sitll a lot, about .5 - .76 inches of slack. When I would hand crank the motor, at certian points there wasnt any slack at all but when I would return to TDC that huge amount of slack was gone.
Any advice would help. What should i do
