1 - 11 of 11 Posts
Turbo Grocery Getter
Anyone know with certainty that a 5mm spacer is sufficent to clear the nx brakes using stock B13 wheels? thanks
nathan
Coropate greed hater
Even though this may not be what you're looking for, but grinding the caliper down to clear the B13 wheels isn't a bad option.
Bitter Old Man
Please don't don't double double post post.
www.FAIRTAX.org
Yes a 5mm spacer is fine but you need longer studs too. The H&R kit includes everything and its about $80.
nathan
4th sr20 and counting..
you wouldnt happen to know the h&r Part number?
Devil's Advocate
nathan
Thought I already answered that for you? Yes it works if 5mm is equivalent to 1/8", I have done it and did not need longer studs. LIke I said once before, once the brakes wear some, you won't even need the spacer.
Just wanted to make ABSOLUTELY sure before i drop $120 on spacers.... not trying to get in a pissing contest here, dont get me on that rant again... i get very irritated with that bullshit. thanks guys for the info.
nathan
www.FAIRTAX.org
The stock studs are not long enough to safely use the 5mm spacers. I took my H&R spacers from rear of my NX to use on the front of my SE-R. I needed them to fit the stock wheels over NX brakes and the lugs kept coming loose no matter how tight they were.
OK, so i need to get the H&R spacers WITH the longer studs then. Awesome, i am gonna keep my car ultra sleeper style.
tlSeR20DE:
I am getting the brakes from new city nissan. I know the parts guy over there and he is cutting me a deal. Loaded calipers and rotors for $219, and he is not worried about the cores being different. Not sure if i can get you th same deal but i can ask if you want. The parts are aftermarket by the way. Are you going to the autocross this weekend?
1/8" is 4mm not 5mm by the way, for all you anal folks on here...
nathan
1 - 11 of 11 Posts
