87 Pulsar NX - Custom AWD SR20DET PARTING OUT!!
anyway, its an 87 pulsar NX, black, paint isnt that great but not too bad.
the good stuff...
fully converted to AWD thru a GTiR transmission with SPEC stage 3 clutch and custom mounted rear subframe from a sentra wagon, bluebird SR20DET is mounted on modified nismo motor mounts.
engine mods are - HKS front mount intercooler, blitz boost controller, 3 inch exhaust, greddy emanage,blitz BOV and 900 hp fuel system with aeromotive tsunami pump, 50lb. injectors, top feed rail, 2 aeromotive fuel filters, aeromotive fuel pressure regulator with autometer fuel pressure gauge and -8an lines all the way back to a automotive 16 gallon fuel cell.
interior - Apexi boost, water temp, EGT, and oil pressure gauge mounted in custom gauge cluster in the dash, autometer 5inch tach with shift light on side of dash pod. Blitz duel turbo timer, grex shift knob.
suspension - all poly bushings, Tein HA coilovers with pillow ball u pper moutns at all corners, NX2000 brakes with hawk pads and Brembo blank rotors. nismo strut tower bar. and gunmetal Jax ultralight wheels with almost new Toyo proxes T1-S tires on them. this setup has a total of 2000ish miles on it.
the car ran a 13.3 at 102 in 90 degree weather. at 1 bar boost, cuts 1.7 60' all day on street tires and finishes within a second of purpose built autoX race cars at many autoXs.
Very neat car, this car is ONE OF ONE, everythign is customa nd no corners were cut in this project. it is the only one in the world like it.
anyway, im asking 5200 but its somewhat negotiable.
email me if you want pictures or more in depth info on the car.
[email protected]
thanks!
cars located near detroit michigan, will deliver within reason and at buyers expense.
