I have personally done ALL of the work on the car, no "shops" have ever touched it. Many parts have also been replaced in addition to the performance ones. I have nearly all the receipts for everything on the car if anyone wants to see them. The car went [email protected] on the old T25 at only 9psi and is much faster now. The New turbo and fuel setup has only been on for about 1500 miles now, and has seen no more than 10psi. I have not had a chance to take it to the drag strip but the car pulls HARD. The car is very reliable and recently was taken on an 900 mile road trip with no problems at all.
Problems:
The cars paint is not in the greatest shape but looks good with wax, as you can see in the pics. The driver seat has a small tear, but the rest of the interior is in good shape. The passenger side fender has a small dent in it, but i have a source for a new fender and i can fix it before the car is sold if you want. The 72lb program idle bad when the car is cold, but tha is mainly because i have not had the time to mess with fine tuning the idle because im in school and living in a dorm.
I would like to get around $8500 OBO for the car seeing as i have nearly 9K into it in parts alone. I am open to all offers and maybe even some trades. Im sure im leaving some things out in the list so email me with any questions and for pics until i can get a good host for them.
[email protected]
94" Sentra SE-R
85,xxx miles
Engine:
- BB DET from JGY(less than 10K since its been in the car)
- Full solid motor mount set
Exhaust:
-revhard manifold
-high temp coated
-Tial 35mm
-Garrett T3/T04E (57 trim, .60 A/R / Stage III turbine, .63 A/R)
-coated exhaust housing
-less than 600 miles of use
-2.5" to 3" DP with flex section
-Daves asspipes 3" exhaust with test pipe
Intake:
-3" intake pipe
-greddy/trust filter with velocity stack
-2" before IC 2.5" after IC piping
-T bolt clamps and silicone couplers at every connection
-26"x6.5"x3" FMIC
-turbo XS type H-34 BOV
Driveline:
-clutch specialties clutch & PP
-new 6 puck sprung disk(less than 1000 miles on it)
-ES shifter bushings on stock shifter
-Redline heavyweight shockproof gear oil
-rebuilt transmission with less than 1000 miles
Fuel/metering:
-JWT ECU
-300ZX MAF
-MSD 72lb injectors
-JGY rail
-Aeromotive FPR
-walbro 255lph pump
Brakes:
-NX fronts
-metal master pads
-new rear pads and rotors(less than 1500 miles)
Suspension:
-GYB GR2
-Eibach Prokit
Wheels & Tires:
-15" bronze rota attack
-205/50/15 Kumho Ecsta 712
-2 new 205/50/15 BFG G-force drag radials(not mounted)
Interior/gauges:
-Autmeter Sport Comp
-boost
-water temp
-oil pressure
-EGT(with team RIP probe)
-Nismo shift knob
-JVC CD player
-Sony speakers(in front only)
Fuel/metering:
-JWT ECU
-300ZX MAF
-MSD 72lb injectors
-JGY rail
-Aeromotive FPR
Misc:
-summit battery relocation
-PC valve cover
-stainless oil feed using stock DET feed port
-ES LCA bushing not installed
-dual stage boost controller activated by fog light switch
-Clifford alarm(needs new remote)
-hood pin
-starter interupt
-exterior and interior proximity sensors
-Dual 10.5" high flow pusher rad. fans
Extra Parts:
-nearly complete lowport motor
-not assembled
-alot of random SE-R related stuff
-AN fittings to build stainless oil return
Problems:
[email protected]
94" Sentra SE-R
85,xxx miles
Engine:
Exhaust:
-revhard manifold
-high temp coated
-Tial 35mm
Intake:
-3" intake pipe
-26"x6.5"x3" FMIC
Driveline:
Fuel/metering:
-JWT ECU
-300ZX MAF
-MSD 72lb injectors
-JGY rail
-Aeromotive FPR
-walbro 255lph pump
Brakes:
-NX fronts
-metal master pads
Suspension:
-GYB GR2
-Eibach Prokit
Wheels & Tires:
Interior/gauges:
-boost
-water temp
-oil pressure
-Nismo shift knob
-JVC CD player
Fuel/metering:
-JWT ECU
-300ZX MAF
-MSD 72lb injectors
-JGY rail
-Aeromotive FPR
Misc:
-PC valve cover
-hood pin
-starter interupt
Extra Parts:
-not assembled
