1 - 10 of 10 Posts
Need to sell due to recent birth of twins. I now have 3 daughters!
Original owner with 165k miles. Color is Super black with mooroof and visor. Interior is in very good condition. Exterior is in good condition with some minor paint fade. No rust anywhere or dents. Car has been excellently maintained throughout its life using Mobil 1 synthetic only. All work was performed by myself and most components are less than 1 1/2 years old.
Modifications:
ENGINE
FMAX STAGE 2 TURBO KIT
TURBONETICS T3/TO4E BALL BEARING TURBO, STAGE 3 46 TRIM .63AR
TIAL 35mm WASTEGATE
HKS RACING BLOW OFF VALVE
93 MUSTANG COBRA MASS AIR FLOW SENSOR
JIM WOLF TECHNOLOGY FUEL RAIL
MSD 50 lb/hr FUEL INJECTORS
NISSAN 300ZX TT FUEL PUMP
FMAX BLUE INTERCOOLER PIPING
FMAX DOWN PIPE
FMAX LOG STYLE MANIFOLD
FRONT MOUNT INTERCOOLER
S&B CONE FILTER
NGK SPARK PLUG WIRES
NGK IRIDIUM SPARK PLUGS
CUSTOM 3" CAT-BACK EXHAUST W/ APEXi N1 MUFFLER, MANDREL BENT ALUMINIZED STEEL
UNORTHODOX RACING ULTRA SS UNDERDRIVE PULLEY KIT (BLUE)
NISSPORT WATER TEMP. ADAPTER
NISSPORT OIL PRESSURE ADAPTER
ENGINE MANAGEMENT
JIM WOLF TECHNOLOGY CUSTOM ECU
ELECTRONICS
GREDDY PROFEC-B BOOST CONTROLLER (CLEAR BLUE)
AUTOMETER LUNAR SERIES MECHANICAL BOOST GAUGE
AUTOMETER LUNAR SERIES ELECTRIC OIL PRESSURE GAUGE
AUTOMETER LUNAR SERIES ELECTRIC WATER TEMP. GAUGE
AUTOMETER SPORT COMP MONSTER TACHOMETER (5" DIA.)
TRANSMISSION
ACT NX9-XTSS CLUTCH
FIDANZA ALUMINUM FLYWHEEL (8.5 lb)
STILLEN SHORT SHIFTER
ENERGY SUSPENSION POLYURETHANE MOTOR MOUNT INSERTS
ENERGY SUSPENSION POLYURETHANE TORQUE MOUNT INSERTS
SUSPENSION
KYB AGX ADJUSTABLE STRUTS
EIBACH SPORTLINE SPRINGS (-1.9" FRONT, -1.8" REAR)
STILLEN ADJUSTABLE CAMBER PLATES
STILLEN STRUT TOWER BRACE
BRAKES
GOODRIDGE STAINLESS STEEL BRAIDED BRAKE LINES
MOTUL 600 BRAKE FLUID
HAWK HPS BRAKE PADS FRONT
POWER SLOT ROTORS FRONT
CROSS DRILLED ROTORS REAR
METAL MATRIX PADS REAR
INTERIOR
CORBEAU CR1 ADJUSTABLE SPORT SEATS (BLUE)
SPARCO ALUMINUM PEDALS
LOTEK PILLAR 3 GAUGE POD ( 2 1/16" )
GENUINE LEATHER SHIFT AND E-BRAKE BOOTS (BLACK W/ BLUE STITCHING)
MOMO COBRA SHIFT KNOB (CARBON)
SOLD
Darwin Award Winner '02
Is this car in good running condition? What is your best quarter time I am just looking for a 13 second car but dont know much about sr20 turbo cars mostly mitsu! lol. Lemme know Thanks P
Car runs great and is my daily driver. Unfortunately with street tires I was unsucessful in getting this car down the track cleanly. It should run in the 13's easily but I cannot back that up with a slip yet. I can tell you, launching with no rpm and gently rolling the car out of the hole making sure not to slip the car ran a 14.3 @ 102-3.
Any offers?
Price Update.
$6500 OBO
This is not one of those bogus "I'm testing the waters posts."
Only Car in Cali W/ Rust!
this car should run 12's with this setup.. someone jump on it.
*edit* my bad.. i was thinking it had det internals.. still should run low 13's ;)
Just to clarify. The BB stood for ball bearing turbo. The car runs 12psi daily and high boost is set at 15psi. This car would really benefit from some cams.
Yes. I'm the original owner. The engine is the original motor. The transmission is the original. The clutch/flywheel have about 15k on it but should be upgraded to a 6-puck.
1 - 10 of 10 Posts
