1 - 8 of 8 Posts
Hey guys... need a little help here...
I've been shopping around for parts and I'm noticing that a lot of places list for 95-98 and not 99. Can I assume 98 parts will fit the 99? Any input would be appreciated.
1-9-9-9 SE Limited
At a robbery anything goes... do whatcha wanna do
· Premium Member
Yes, all performance parts from a '95-'98 will fit. Body parts might not.
Eric Waterman
1996 200SX SE-R
1997 200SX SE-R
1991 Sentra SE-R
hey, natty. just about every mod you can do to a 98 can work on a 99. the prob is most aftermarket places (for some strange reason) don't think a 99 SENTRA SE is the same as 98 200SX SE-R and the same engine as a SENTRA SE-R.
stiletto
99 Sentra SEL platinum gold w/ HS headers and CAI, custom b-pipe, arospeed exhaust, magnecor 8.5mm wires, eibach pro-kit, courtesy nissan frt and rear STB, smc short shifter, greddy knob, jwt clutch, k&n crankcase breather, 17 deg. timing, EL indiglo HVAC, clear corners and taillights and not a single stock bulb.
Cool... that clears that up. Thanks.
1-9-9-9 SE Limited
· Premium Member
Welcome to the board Luis. JWT does make a ECU for the '99. Its called get a '95-'97 ECU, and redo a few wires
the exhaust system is a little diffrent than the 95-97 models, but everything else should work. also, the place racing intakes are diffrent b/c of the air temp sensor.
1 - 8 of 8 Posts
