A little update on my 240
11905 Views 73 Replies 16 Participants Last post by  Yellow4g63
The final part that I have been waiting for the get the rest of the project started is 98% done. It's getting coated right now then the O2 housing is going to be made.
See less See more
8
1 - 20 of 74 Posts
Wow man. :eek2:
What are your goals with her?
Chris
Get it running and drive it lol.
rb25? i could be wrong.
Looks good man
Looks good man
RB20 rev monster.
OMG thats going to be sick :biggthump
why did you decide to go with an rb20? good price i would assume?
At the time (5 or 6 years ago) I was going to go with a SR20. I had to wait so long that I changed my mind and wanted to try something new. Joined a RB forum and listened to what everyone said. Then I picked the RB20 and haven't looked back. My friend picked the RB25 and we have raced more than a few times. :) that's about all I can say on this forum about that. My next 240 is going to be RWD SR20VE.
You should probably have the turbine housing flange of that manifold decked...theres definetly some serious imperfections there.
Negative ghost rider, The pattern is full. It's just the way it looks with my crappy camera.
Dang i know it will happen ...hehehe
It's just a Ceramic Coating Protech gets done on there manifolds if the customer wants.
Not sure which hood pins to run, I want to keep the stock lock and latch but the hood didn't want to close right. My car didn't come with a hood :( so who knows why it was off lol.
See less See more
3
Nice build man!! Gimme some specs on the RB20 please. May be a good option for a 240.
I'm busy with my s13 which came with a JDM CA18DET at the moment.
Stock rods/pistons. Tomei headgasket, Tomei valve springs, Tomei 270deg intake and exhaust cam, Nistune Ecu daughter board, 800cc Deno top feed injectors, Protech Manifold, SC61 turbo with Stage 5 exhaust wheel and E cover, FMIC, Apexi GT spec Exhaust, Protech O2 housing and downpipe. I have full 300zx brakes front and rear with the Ebrake backing plate that I'm going to put on after the car makes smoke. a few Defi gauges (oil temp and water temp) STRi 30psi boost gauge. Also found the R32 diff to match my trans too, want to put a 1.5 way clutch LSD in there when I get some money. Koyo radiator (wanted a Griffin but they were way back ordered at the time :() I'm trying to find the factory RB25/RB20 fan so I can put the Fan clutch setup back in, Hate the freaking Fal220's suck too much power from alternator. Had my harness converted by my Friend CarlH on 240sxforunms, he did a bang up job for me and even put in a resistor pack into that harness and make it look factory :biggthump. Have a oil cooler setup that all I need are the lines made to use that will go on a little later.
See less See more
CarlH as in the same one in NC? If yes, I know the Carl. I also enjoy hanging out with the Carl.
What hood pins did you choose?
Yup thats the same CarlH, I haven't even picked one yet. Prob the cheap $20 ones.
Sweet.
Um, why? You've spent all that money, have a CF hood, and are thinking about using $20 hood pins? :confused: I tried them, and they suck.
1 - 20 of 74 Posts
