<font face="Verdana, Arial" size="2">Originally posted by RAFSE-R:
will i have trooble with ABS when i do the upgrade. i'm not purchasing a kit i'm getting everything out of the junk yard</font>
I am not going to say "no". But, on the other hand, on my 1991 ser when I did the NX brake upgrade, I had no problems and I do have abs. I cannot think of anything that would effect the abs unless you werea monkey and screwed something up in the install and damaged one or more of the sensors, in that case, duh, the abs will not work. But there is no reason that the abs should be affected by the swap. All the ABS stuff is attached to the hub and not to the caliper, so there will be no problems...
Why are you going to get it from a Junk yard? Why not just goto peb boys or schucks or whatever the hell your local parts store is? I mean, come on! THEY ARE YOUR BRAKES! DO NOT SKIMP HERE! And yes, I was yelling =)
David Lau <
[email protected]>
Stop Fast, corner better B13 SER in Vancouver, WA
