21 - 40 of 63 Posts
93W91SER said:
I wanna see some pics installed on a b13. I understand the concept, but I justa want to see it installed.
Chuck, we need an installed picture on a Cup car or an ITA car.;)
I Keep It Unique
Excuse my ignorance but couldnt you just flip the existing ball joint over and mount it to the underside of where it mounts to the hub instead of the top like stock?
Discussion Starter · #25 ·
the tierod ends have a tapered seat in the steering knuckle.
think of it this way ...................... when you lower a car, you want to lower the pick-up points to put them back in roughly the same place.
-chuck
search "bumpsteer"
I Keep It Unique
Ok just asking sometimes pointing out the obvious which is often over looked is the answer but I guess not in this situation.
Discussion Starter · #27 ·
ok
finally got these done!!!!!
the kits consist of a drop-in stud that allows mounting over/under the steering knuckle, adjusting spacers, locknut, rodend, jam nut and tierod to rodend coupler.
for most cars these will help bumpsteer issues by lowering the tierod piviot point.
they allow about 0"- 3/8" (from stock) adjustment mounted over the knuckle, and about 1 1/2" - 2" mounted under the knuckle.
these come real close to binding at full droop, but high mis-alignment rodends would have comprimised the ability to move the piviot point closer to the knuckle (where most cars would be using them).
IMPORTANT NOTE
these come very close to binding on a stock suspension!!!
how well these would suit your application i cannot predict
buyers assume all resposibility for fit, function, set-up and safety of this product.
$150 shipped ($25 discount for forum supporters)
e-mail orders to : [email protected]
when ordering include your name, address, ship address, telephone #, sr20forum user id, car year and model.
payment can be made by:
paypal id = [email protected]
money order =
chuck olcott
bolt in bars
5117 n 35th dr
phoenix az 85019
Now accepting donations!!
what's the degree range on those rodends?
Charlie Brown look alike
Now I just need to decide whether this will work with my setup. Nice work, very nice work.
Will these work on a B14? I have always understood the "frontends" were the same between B13 and B14.
Also, what kind of driving improvements do these provide for an autocrosser? I guess I understand the mechanical benefit, but I do not have the experience to imagine the practical gains that is must provide. Thank you
Discussion Starter · #32 ·
according to checker auto parts,
1995 - 1998 200SX
1987 - 1990 PULSAR NX
1989 - 1994 240SX
1986 - 2005 SENTRA
1996 - 2001 ALTIMA
1986 - 1989 STANZA
all use the same tierod end.
so i would say yes
as for how well these would suit your car ............................ it depends if you are experiencing bumpsteer problems and to what extent.
Professor Dingbat
This tendancy could be reduced using coned spacers.
You could also extend the range slightly by grinding down the edges of the steering knuckle where it impacts the rod end.
Discussion Starter · #34 ·
all of the cone spacers i have seen have the same smallend diameter as the rodend ball face. cone spacers are better suited for use with 3 piece rodends, where the body would be binding in a clevis mount situation. a cone spacer is about a 1/4" thick. this would diminish the adjustable range as well as put the rod end in a position where bind wouldn't be a concern.
i chose to use a two piece rodend for this very reason.
G20.net member too!
Chuck, will these work on P10/P11's
Ego Destroyer On Board
interested in one set for my sentra, any possibility for maxima MY00 ??
I saw the list so my hopes are not so high, but heck I might try on my Maxima.
ok i would like to try these out. Now the question is will it work on the RNN!4 chasis? Im leaning toward it will . But does anyone know for sure?
21 - 40 of 63 Posts
