<font face="Verdana, Arial" size="2">Originally posted by Pretty White:
Andrew thing is that in a classic if you are looking thru what is supposed to be the brake duct in the chin spoiler you are going to see the airfilter. That is a definate plus for the CAi @ high rpms.</font>
Don't forget the B14, as the foglight is in front of the filter and would be blocking airflow.
The NX2000 has no place for air to go to the filter. At higher rpms the car will be chocking (IMO) becasue there is no additional air being supplied to the intake. It is sort of boxed in.</font>
But that statement would also apply to the B14's as there is no additional air as well. If that area where the filter is located is completely sealed and airtight, then you have a case, but that area is NOT sealed and airtight.
<font face="Verdana, Arial" size="2">At lower rpms I would not think this would be a problem. That is why Ray K. posted of someone in a NX2K losing like 5hp with it at high rpms.</font>
I would be really interested in seeing this dyno chart if you could get your hands on it. Losing 5hp at high RPM's compared to what? JWT POP? Stock Airbox? Open Airbox?
<font face="Verdana, Arial" size="2">I know that when I had the Place racing intake on my car it felt slow asa dog at high rpms. I took it off as soon as I put it on. At that point I liked the JWT POP with the Warm air set up the best.</font>
SOTP and IYHO.
<font face="Verdana, Arial" size="2"> I still sort of like that set up best cause my car used to chirp 3rd gear with that set up as opposed to the CAI which I could barely chirp 2nd in back ot back comparison tests.</font>
I really don't think that has any bearing on whether the CAI works or not.
It works... It's been proven. It draws cold air from outside of the engine bay. The smoothness and length of the intake piping also contribute to the power gains. You can't tell me that a CAI isn't worth it on an NX, though I would be more inclined to believe that a CAI doesn't work as well on an NX as it does on a Classic.
Apples to oranges comparison: AEM CAI's for the Honda cars. I remember installing one on a friend's '98 Integra GS-R. Filter is completely blocked from fender liner to bumper cover (though removing the turn signal lens helps). I would have to say it is as blocked as in the NX, though by really inaccurate SOTP impressions, the car indeed felt faster, though we didn't dyno the car or take it to the track to see how much of a difference. But seeing other dyno charts for the same car on SCC, it gained power... It gained good power.
Okay... I'm losing track on where this discussion is going... But going back to the original post...
silversx: They are worth it... Whether you want to spend the money on one is your choice. You still have the JWT POP as your alternative... Considering you're so concerned with getting an underhood intake, just get a POP and be done with it.
--Andrew Phan
1993 NX2000 (open airbox for increased sonic performance and ghetto cheapness)
1998 200SX SE-R (Hotshot CAI, birthday present)
[This message has been edited by RollcageSR20 (edited 09-14-2001).]
